d16y8 blown headgasket went out
Old Sep 3, 2010 | 10:26 PM
otek // ek.dipn's Avatar
Default d16y8 blown headgasket went out
best route? Anyone selling gasket kits on this site? Should i stick with oem or go cremetic? I hear alot of different opinions. So I'm going to ask the question now to get my answer.
i hear a cremetic with a oem on top? whats the real best way to go? the engine is completely stock.
Old Sep 3, 2010 | 10:41 PM
mouab18c1's Avatar
Default Re: d16y8 blown headgasket went out
If you dont plan on racing it Napa gaskets are fairly good. Im actually sporting one in my GSR right now. No leaks what so ever.
Old Sep 3, 2010 | 10:57 PM
im no mechanic but im sure i can do it myself. i should get the whole gasket set? including all this..
- Intake manifold
- Exhaust manifold
- Cylinder head gasket
- Valve cover gasket
- Cam seals
- Valve seals
- Valve cover seals and grommets
- Injector seat o-rings
im trying to find pictures showing where the "valve seals" the "valve seal grommets" these are very small and I'm not too sure where all these go.... and this will be my 1st headgasket repair XD
Old Sep 4, 2010 | 06:09 PM
SiR831's Avatar
You should be fine with a head gasket kit set from Honda...It will include the valve guide seals as well...But not the injector o rings.
B16B Four Door
Oct 27, 2011 05:45 PM
skate1968
10
Sep 2, 2010 04:34 AM
caliskier
Mar 22, 2009 04:45 PM
darkfx
Oct 8, 2005 09:51 AM
sleepyIntegra
May 26, 2004 03:43 AM
