sir cluster swap in 95 si
Old Sep 3, 2010 | 06:24 PM
CivicSi95's Avatar
Default sir cluster swap in 95 si
by not plugging in the srs and cruise control plugs, does it have any effect other than the lights dont light up?
Old Sep 3, 2010 | 07:26 PM
94EG8's Avatar
Seagull Management
Default Re: sir cluster swap in 95 si
The SRS wont function, the light completes part of the circuit, IIRC cruise is the same way. You can easily swap the SRS light in (use the bezel from your old cluster that already has the hole cut in it. Cruise is more work., you'll have to jump a couple of pins on the plug.
Old Sep 3, 2010 | 08:31 PM
tlarimer's Avatar
Cruise will work perfectly fine, just no light in the cluster. SRS I'm not sure about.
WiedemannC
Honda Civic (2001 - 2005)
Oct 22, 2010 04:33 AM
SIDreamer
Feb 9, 2010 08:04 PM
cloudconnected85
Sep 28, 2008 12:43 AM
CeeJayy
Aug 25, 2007 09:06 PM
flatblack-h22
Mar 23, 2006 10:04 AM
