swap from dpfi to mpfi
Old Sep 3, 2010 | 03:14 PM
civicd15's Avatar
Post swap from dpfi to mpfi
whould it be better to swap from dpfi to mpfi or swap another d series in my 4 door 91 civic what would be the best d series to get
Old Sep 3, 2010 | 03:33 PM
mattliston's Avatar
Default Re: swap from dpfi to mpfi
Search instead of making a thread
This type of thread is expected for perhaps 10 years ago, but not now.
TONS of information on here for you to find.
Use the search bar
Old Sep 10, 2010 | 06:42 PM
civicd15's Avatar
when doing the mpfi swap if i just swap the all the motor wiring i dont have to splice the ecu do i
Old Sep 10, 2010 | 11:06 PM
D16SiHatch's Avatar
you can't just swap to a mpfi engine harness unless you also switch out the cabin harness. much easier just to add the few wires you need and run them into the car. you can even use an old connector if you like to run the wires through so that if you ever need to disconnect the harness completely from the car you won't need to pull those wires back out of the cabin.
Old Sep 10, 2010 | 11:22 PM
ryanevansoh's Avatar
read this over and see how easy mpfi is...
fminusmic
11
Jul 21, 2018 10:24 AM
1990vtecsedan
Nov 8, 2012 03:00 PM
thatblkguy
Jan 29, 2010 05:02 AM
jeffruby
Aug 18, 2006 07:46 PM
Vaans
11
May 3, 2005 10:17 AM
