99 Sable Charging System Issue
Old Sep 3, 2010 | 02:45 AM
EHondaJDM's Avatar
Default 99 Sable Charging System Issue
My alldata is down
I just recently put a alternator in a 99 sable DOHC. After installing it, it still will not take a charge. I've put 2 diffrent alts in and if you've installed one of there ull know how much of a ***** it is.
I've checked all connections and fuse everything is good.
For some reason the battery light was not turning on at all even when the key is first turned on accessory so I switched the bulb and it still doesn't light up.
Anybody know if there are any modules or relays connected with the charging system that would be causing this?
TIA
Old Sep 4, 2010 | 10:01 AM
EHondaJDM's Avatar
Default Re: 99 Sable Charging System Issue
recovery69
Oct 19, 2009 05:15 AM
