Weak Front Turn Signal
Old Sep 2, 2010 | 11:01 PM
ballerchild's Avatar
Default Weak Front Turn Signal
Probably a rookie question, but I'll ask anyways. My gf's 98 accord has a weak front passenger side turn signal. On the dash when the signal is activated, it blinks real fast. The signal on the driver side front/back are working just fine. So does this suggest a bad bulb or a bad turn signal relay/or fuse?
Old Sep 2, 2010 | 11:11 PM
teggi's Avatar
Default Re: Weak Front Turn Signal
bad bulb
Old Sep 3, 2010 | 04:29 AM
Atreidies's Avatar
Your blinker fluid is low.
Old Sep 3, 2010 | 10:22 AM
H22AFerio's Avatar
Most deff bad bulb, But I would check the blinker fluid to
Old Sep 3, 2010 | 10:40 AM
slamstrom's Avatar
Bad bulb is on the side that's blinking faster.
Old Sep 3, 2010 | 11:30 AM
good looking out fellas. I'll make sure to check the blinker fluid also
Old Sep 4, 2010 | 07:31 PM
soon2bdropped's Avatar
bad bulb. if left front turn signal is out the rear turn signal will blink fast. vice versa.
lothian
Jul 19, 2017 07:05 PM
jacreech777
Lighting
Aug 5, 2016 02:27 PM
QuikSilverMD
Apr 21, 2011 11:18 AM
batallic
Mar 18, 2008 08:47 PM
mikkellucci
Honda Civic (2001 - 2005)
19
Aug 22, 2007 02:31 AM
