Gsr crank in ls block
Old Sep 2, 2010 | 08:32 PM
matt2320's Avatar
Icon2 Gsr crank in ls block
Hey guys, I've done some searching on this topic and havent found a solid answer. I'm putting togeqther a spare motor from parts I have layin around. I will be using a b18b block gsr crank,ctr pistons w/a b16 head. My question is will the gsr crank work with ls rods or would I have to run gsr or even custom leingth rods? From what i kno the stroke on the gsr crank Is 2 mm smaller than the ls, witch should provide some valve clearence for the pistons and the use of a larger cam.
Any info would be useful as to the rods would be helpful.
Also, would I gain more power or torque throuht the powerband with this block/ crank setup?
Thx again
Old Sep 2, 2010 | 08:50 PM
cibao2ner's Avatar
Default Re: Gsr crank in ls block
gsr crank u need gsr rods...ls crank ls rods...gsr rods are 137.9mm and ls are 137mm...it might work like using a 2mm thicker headgasket...but u wont know till u try it...assemble it and see how it looks..
Old Sep 3, 2010 | 10:05 PM
matt2320's Avatar
^ true. Bump ne one else have any insight pertaining to this?
Old Sep 7, 2010 | 04:42 AM
kyden's Avatar
ls rods won't fit on a gsr crank anyway, so you'd be wasting your time. get gsr rods.
carlossolorzano
May 27, 2012 01:12 AM
patrick4588
Oct 18, 2007 12:33 PM
bigbadboy
Aug 28, 2006 06:20 PM
electric_rex
Dec 5, 2004 02:57 PM
