95Accord -jdm (94)h22a and ldd lsd tranny
Old Sep 18, 2002 | 12:15 AM
Showoffnyc1's Avatar
Default 95Accord -jdm (94)h22a and jdm Lsd tranny
I got an h22a jdm and lsd tranny jdm and p13 jdm ecu what is the redline for it ? i took it once to 7,900 rpm's (cant tell my redline i have a 95 accord) and top speed is 116 mph what the hell on a Lude ? u think i got an type S tranny and i have close ratio gears because i stay close in all my gears ? i know lsd tranny did not come till 97 so i got luck to get an 94 motor with 97 lsd tranny where i could fine redline for my motor and why i top out at 116-120mph its jdm ecu ?
[Modified by Showoffnyc1, 9:16 AM 9/18/2002]
Old Sep 18, 2002 | 04:12 AM
Kazmans94cord's Avatar
Default Re: 95Accord -jdm (94)h22a and jdm Lsd tranny (Showoffnyc1)
give it to me and i will show you.
Old Sep 18, 2002 | 05:19 AM
93AccordCoupe's Avatar
Nope. 94 Ludes have extremely short gears. You should be topping out at 116mph. Nothing is wrong. Remember, shorter gears on all motor = good. And your car should be running to 8000rpm with the p13 ECU.
Old Sep 18, 2002 | 07:04 AM
Default Re: 95Accord -jdm (93AccordCoupe)
Thanx for that info .. I looked today at my Tranny and i seen thse numbers p15 or 16 and soemthing like Y1k something like that is that close to Type S tranny ?
Old Sep 18, 2002 | 07:38 AM
H23 Power's Avatar
Default Re: 95Accord -jdm (Showoffnyc1)
the p13 jdm ecu has a top speed limiter...you have to get it chipped to remove it...
after its removed the top speed will be around 140-145 i believe
the redline is 7200-7400...fuel cut is 7600, which is probably around 8k on your stock tach...(they are off at high rpms)
Old Sep 18, 2002 | 07:48 AM
greensleeper's Avatar
Default Re: 95Accord -jdm (F23 Power)
so is it the gearing or the ecu that keeps him down to 116?
what engine speed are you running at when you top out?
Old Sep 18, 2002 | 08:14 AM
Nick M's Avatar
Default Re: 95Accord -jdm (greensleeper)
The ECU limits top speed with the JDM P13.
I believe the redline is the same as USDM 4th gen h22a's despite having different cams.
Old Sep 18, 2002 | 11:01 AM
CD8's Avatar
CD8
Default Re: 95Accord -jdm (HondaSport)
1. LSD transmissions were availible as an option for all preludes/sir-t accords 93+
2. even with the type S tranny, you will not be topping out at 116. that is rediculous...
3. redline is 7400, fuel cutoff is 8000
look at the code on your tranny. i can tell you what its from...
[Modified by exaccord, 12:02 PM 9/18/2002]
[Modified by exaccord, 12:03 PM 9/18/2002]
Old Sep 18, 2002 | 02:33 PM
H23 Power's Avatar
Default Re: 95Accord -jdm (exaccord)
fuel cut is about 7600. its just indicated at 8k because the stock tachs are off at that point.
Old Sep 18, 2002 | 03:18 PM
Nick M's Avatar
Old Sep 18, 2002 | 04:30 PM
CD8's Avatar
CD8
agreed... my tach is off crazy i think... i need a not stock one. anyone know the differences between mechanical and electric?
datap1mp
May 27, 2003 06:14 PM
Showoffnyc1
Sep 18, 2002 05:35 AM
