Precision 1000cc low impedance injectors & resistor box w 96+ pnp harness
I was using the pnp resistor box setup on my 2000 Honda civic. I'm pretty sure it will work with all 96+ Civics. If you want to verify it will work before you buy it check your dead connector with the instructions listed in this thread Complete DIY Plug and Play OBD2 Civic Resistor Box Write-up EJ6 EJ7 EJ8 EM1 EG1 EG2 EH6 - Honda-Tech .The resistor box has a bracket attached to it to mount it in any 96+ civic for a very clean look.
One of the injectors is missing a small plastic ring and it can be see in the pictures. This to my knowledge doesn't affect anything. I have been using these injectors for around 8k miles and made close to 400hp on ethanol with these. These are Precision brand low impedance injectors and take obd1 Honda injector clips.
I want 225 shipped for everything or 205 for the injectors and resistor box. I Will sell the harness by itself for 20 shipped. I will only start selling stuff separately if the injectors sell.
immorality
May 24, 2008 03:46 PM
nasteboyii
Mar 30, 2004 01:20 PM
