Help with 94 GSR brakes
I have a 94 GSR, when stolen, they took the ABS and lines. I ran new lines to the front, changed the master cylinder to non ABS, and got a prop from a civic SI. For some reason the brakes will not blead out, and only the front driver side works. Can anyone help with this problem ?
Ok, Ill try switching lines around. Should I buy a new prop for a RS Integra ? I read that it has a 40/40 ratio, could that play a factor in my problem ?
how long did you try bleeding? are you not getting any fluid to the bleeder? what exactly is happening when you try bleeding?
you have to make sure you have the same configuration now as it was before.
you may have the lines mixed up at the prop valve. or, the prop valve may be configured differently
goldfinger93030
Sep 19, 2010 07:33 PM
