B18C1 Oil PCV/Breather Issues
Old Sep 2, 2010 | 06:44 AM
af1racing's Avatar
Default B18C1 Oil PCV/Breather Issues
I have blown 2 B18C1's trackside in 2 weeks. The last one had only 4 race miles on it when a rod came through the block and was OEM with no modifications running under 7000RPM.
The issue appears to be the craptacular oil breather canister on the engine. The way it is hooked up is as follows.
A canister is located on the floor of the cockpit. A tube runs from that to the PCV canister output that would normally go to the manifold. A second tube runs from the valve cover output (by the oil cap) to a different canister located by the clutch reservoir.
For whatever reason, these engines are pissing out all the oil in a matter of minutes and then seizing.
Any ideas?
We have 1 block / head left and I don't need another engine grenading on us this late in the season.
Old Sep 2, 2010 | 11:33 AM
vtecbuilt's Avatar
Default Re: B18C1 Oil PCV/Breather Issues
mount the can higher and remove the black box and add a drain back there and make sure your can is vented.and i would leave the breather on the valve cover open
V-SPEC 1
Feb 18, 2014 02:18 PM
jdmfoglights
Jan 8, 2014 09:50 PM
laziebun
Dec 15, 2008 07:56 PM
SkoundrelUSA
Oct 15, 2006 02:29 PM
Dr Pooface
Sep 26, 2006 08:36 AM
