S2 Pro2 degreeing
i use the Pro2 on my H22A engine and need folowing Info please:
are this infos @ 0,04" (1mm) or 0,05" (1,27mm) valve lift???
Intake:
Opening: 31° BTDC
Peak lift: 99° ATDC
Closing: 46° ABDC
Exhaust:
Opening: 58° BBDC
Peak lift: 106° BTDC
Closing: 25° ATDC
Intake:
270°/12.8 @ 1mm / 0.000” lash
Exhaust:
276°/12.0 @ 1mm / 0.000” lash
http://www.skunk2.com/camshaft_tech.php
http://www.skunk2.com/installation/305-05-5205.pdf
Intake:
Opening: 31° BTDC
Peak lift: 99° ATDC
Closing: 46° ABDC
Exhaust:
Opening: 58° BBDC
Closing: 25° ATDC
Intake:
Exhaust:
those numbers look like they are at 1mm lift. but when you degree them, you will not be able to get those numbers...every S2P2 cam ive seen is ground different than the cam card says. your best bet is to install them based on the peak lift numbers. (use "helpful tip 2" in the first link you posted) be sure to check your clearances also (piston to valve AND valve to valve).
mejim707
May 15, 2009 09:52 PM
