d15b7 start up problems need help plz!
Old Sep 2, 2010 | 12:24 AM
dc4pssthoy's Avatar
Default d15b7 start up problems need help plz!
ok i was just driving down the interstate and all of a sudden my car dies
we tried jumping it and that was a fail
so i tried getting a new dizzy and that failed
and tried another obd1 ecu to check if that just went bad
every time i try to start her up the fuel pump engages and the engine turns over just doesn't run im puzzled
any ideas what the problem could be?
if this helps the motor sounds like its dying when its turning over
THANKS FOR THE HELP
Old Sep 2, 2010 | 06:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: d15b7 start up problems need help plz!
Have you checked to see if the problem is no spark or no fuel yet? 94
Old Sep 2, 2010 | 11:11 AM
dc4pssthoy's Avatar
yeah i dont think im getting any spark but i am getting fuel
Old Sep 8, 2010 | 11:43 AM
alexeugene83's Avatar
well i am having a similar problem. let me know what you find out. thanks
Old Sep 8, 2010 | 12:05 PM
Crashtestdummy's Avatar
Hey i'm just curious about this but was it raining when this happened? If so could be damp or even damaged distributor components
Old Sep 10, 2010 | 02:59 PM
Hamarti's Avatar
I had the same problem with my b7. It turned out to be the grounds that are bolted to the thermostat housing. Check that, and the main battery ground for corrosion(both ends, battery, and body), clean them up, check to make sure the ends aren't loose. Hope that helps. gl
Old Oct 10, 2010 | 10:19 PM
dc4pssthoy's Avatar
yeah turns out that when i dropped a gear then i skipped time so i ruined my head and bent the valves and all that good stuff but got a new car now haha
k_vd16
Feb 5, 2011 01:42 PM
93daintegra
Sep 30, 2008 04:58 PM
cbrracer91586
May 19, 2007 04:31 PM
hurraquio
Feb 4, 2006 07:34 PM
stubk20
Oct 18, 2005 06:44 AM
