HKS Super Flow Air Filter, HKS Grounding Kit, Auto Meter Pro Comp II Tach
First off is an Auto Meter 2 Pro Comp 5" Tachometer with shift light. You all probably know what these are. Can work on any vehicle including autogragics (if you want to be all badass Vin Diesel minus the functionality) but are optimal on manuals. Programmable shift light memory, up to 10k rpm. Real deal holyfield brand new in box. Light up a sick hyperwhite at night with giant red shift light sure to get you ***** before 2012 and the zombies attack. This is the 3669 model btw.
Price is 179.99 shipped to your door. These usually sell for well over 200 bucks at retailers.
Next up is a genuine HKS Super Power Flow 'Reloaded' 200mm universal air filter. Pretty badass. 200mm (effin massive) in diameter and 90mm in height and will fit on any standard 3" (80mm) tubing. Optimized for turbo applications but will work effin awesome for the rest of us naturally aspirated ****.rars. Shitload of surface area, pretty sick looking chrome honeycomb cage, 3 layer patented filtration design, and a brushed gold rear surface. Brand new in box and read to install.
Price is 59.99 shipped to your door.
And lastly, HKS engine grounding wiring kit. I believe this is 8 gauge wiring, supplied with more than enough wire to do your entire engine bay AND SOME. Red (no blurple or pink fail ****) insulated high density copper wire with silver plated end leads...comes complete with gold bolts/nuts brackets and zipties to do the entire installation. Wiring and end leads to do 5 total components (battery, alternator, engine + 2 amps). A great upgrade from your old worn down factory ground wiring. Brand new.
Paypal verified premier business member. Get @ me if interested, thanks!
