cable to hydro b swap in wagovan, which t bracket to use?
Old Sep 1, 2010 | 07:36 PM
revikan's Avatar
Default cable to hydro b swap in wagovan, which t bracket to use?
My friend is doing a b20b swap in his wagovan, hes already bought innovative cable to hydro mount kit. Hes gonna get either a b16 tranny, or gsr which ever he finds at the right price. I've looked everywhere, but which t bracket does he use? Does he use a cable integra t bracket or a hydro integra t bracket? thanks
Old Sep 1, 2010 | 07:44 PM
littlewagon's Avatar
Default Re: cable to hydro b swap in wagovan, which t bracket to use?
Did the same swap to my wagon. Go with the cable transmission rear bracket.
You will have to enlarge the holes slightly on the bracket for the bolts that go through bracket and into the transmission itself. The reason is the bolts for the hydro trans are slightly larger in diameter. What are you using to actuate the clutch?
Old Sep 1, 2010 | 08:06 PM
revikan's Avatar
im not sure what hes using. all i know is he bought the innovative cable to hydro mount kit. lol
Old Sep 1, 2010 | 08:08 PM
hush22's Avatar
^^ It sounded as if they are going to use innovatives cable actuator.
to further answer question more specifically use a 90-93 integra rear t bracket and continue the aboves instructions
Old Sep 2, 2010 | 04:27 PM
bryse68's Avatar
90-93 integra rear bracket and drill it out with a 14mm drill bit.
400hpcrx
Jun 24, 2014 10:59 AM
mouab18c1
20
Jul 9, 2013 11:36 PM
allmotor1313
Mar 10, 2008 08:13 PM
mattcivic
Jul 19, 2006 06:56 PM
