civic staggered set-up
Old Sep 1, 2010 | 07:18 PM
peak_boost's Avatar
Default civic staggered set-up
did you know if i can run one of these 2 setup on my 2005 coupe.
first setup my favorite
for the front is 16x8 in +50 offset
for the back is 16x9 in +38 offset
and the second is
for the front is 16x7 +38 offset
for the back is 16x8 +25 offset
Old Sep 2, 2010 | 07:23 AM
toyomatt84's Avatar
Sanji
Default Re: staggered set-up
Originally Posted by peak_boost
hi
i look for a staggered set up for my ride in 16 inch
whats the maxium offset and the width i can put in 16 inch
all my thanks
It all depends on the purpose of the car. Are you going for looks or performance? And even then, if performance is your goal... are you going for drag racing or track racing?
Old Sep 2, 2010 | 08:42 AM
peak_boost's Avatar
its just for the look i dont drag or race my car
Old Sep 2, 2010 | 08:56 AM
toyomatt84's Avatar
Sanji
Then I can't really help you.
Old Sep 2, 2010 | 10:24 AM
alphalanos's Avatar
Just find a set of lightweight wheels and put some sticky tires on them.
Old Sep 3, 2010 | 01:41 PM
peak_boost's Avatar
helpp!!!!
Old Sep 4, 2010 | 05:30 PM
peak_boost's Avatar
Default Wheel
Old Sep 5, 2010 | 06:28 AM
peak_boost's Avatar
Old Sep 5, 2010 | 07:09 AM
Harlowe's Avatar
Function>Fashion
16x8 +25 & 16x9 in +38 - isn't going to fit without rolling the fenders and running too much camber.
16x8 in +50 - Not sure if this will clear on the inside of the wheel wells. Pretty high offset.
16x7 +38 - will fit front/back just fine.
Old Sep 5, 2010 | 07:10 AM
pjdm's Avatar
aiight i dont really post much but here is my setup i got 16x8 +15 ALL AROUND!
Old Sep 6, 2010 | 12:33 PM
1jcivic's Avatar
Default Re: civic staggered set-up
If your going for looks just buy the wheels you want in the size you want and GET THEM TO FIT.
Anything is possible with the right camber, tire size, and a bit of rolling the fenders.
Old Sep 7, 2010 | 12:42 PM
alphalanos's Avatar
Yeah but its not safe. Im all for making stuff look good, but keep it safe. Camber = ok to a point. Tire strech = no.
Old Sep 7, 2010 | 04:29 PM
nsxtasy's Avatar
H-T Order of Merit
and the second is
NEITHER.
Depending on what version of the 2005 Civic Coupe you have, your best 16" tire size is either 205/50-16 or 215/50-16. Neither of those sizes can be safely mounted on 16x8 or 16x9 wheels. Stick with 16x7 on all four corners.
96romaEK
Feb 13, 2010 04:05 AM
Boosted B6teen
Dec 13, 2006 10:40 AM
skeelo
Oct 27, 2005 07:17 PM
hecklervtec
Jul 2, 2001 05:42 PM
