b20 ef hatch
Old Sep 1, 2010 | 04:24 PM
jdmda_1.7a's Avatar
Default b20 ef hatch
sup H-T am putting a b20 in my ef hatch and i came across this gsr shift linkage ..i was wondering if i still had to cut and weld some of it just to fit my b20??i know the ls shift linkage you do but are the gsr different?..if anyone knows that would help a lot
Old Sep 1, 2010 | 04:37 PM
jdmda_1.7a's Avatar
Default Re: b20 ef hatch
bump
Old Sep 1, 2010 | 05:38 PM
D16SiHatch's Avatar
i've never heard someone say you could use a dc linkage so i presume that it can't be modified/shortened to fit like a da linkage. if i had to giess i would guess that the linkage itself would hit some portion of the underside of the car and hinder function if you tried to use it
Old Sep 1, 2010 | 07:39 PM
bfatdaintegra's Avatar
the gsr and ls shift linkage is the same dimensions,you need the b swap linkages avid,or hasports are the best even innovative.the integra shift linksges are too long like a inch or so. Ive done this in a ef hatch before ive cut and relocated the shifter hole in the floor back a few inches and it worked it even looked stock when the center consol was in
Old Sep 1, 2010 | 08:11 PM
jdmda_1.7a's Avatar
thanks guys for your input..am just gonna go with a hasport for my swap.that way it will be done right
Old Sep 1, 2010 | 09:17 PM
hatchet_honda's Avatar
that 100 bucks is worth having a good working shifter IMO lol
Old Sep 2, 2010 | 05:30 AM
ExtremeLighting's Avatar
Hey guys, David here and need some help on whats needed for a B20 with a Type-R head? ik i have to spin the bottom end to 11,000, but if you can plz help
Old Sep 2, 2010 | 12:32 PM
jdmda_1.7a's Avatar
u will need a vtec kit..i will go with golden eagle that's just me ..make sure u get some good head studs to!if u want to get in high rpm
Old Sep 2, 2010 | 03:50 PM
D16SiHatch's Avatar
if by head studs you mean arp rod bolts then yes
Old Sep 4, 2010 | 09:19 PM
Ill be having the motor by next summer but not the head so im gonna save up for another summer to do everything.. im looking into the B20Z
Old Sep 4, 2010 | 09:39 PM
is there a way to beaf up the sleave and what type of piston would be best for the B20Z Type-R?
Old Sep 4, 2010 | 10:02 PM
.Manny.'s Avatar
Touching My Member
Just so you guys know, a cut and welded GSR linkage feels 10 times better than any aftermarket linkage. speaking from experience.
IIRC the linkage has to be cut 2 3/8 of an inch.
Old Sep 5, 2010 | 12:39 PM
jdmda_1.7a's Avatar
thanks .manny..i had people tell me the same thing..to bad i already order mine lol
Old Sep 5, 2010 | 06:44 PM
mattliston's Avatar
B20 guy>>>HASport linkage. DA linkaage fits sedans only I believe.
Extreme lightning. Start your own thread
I will say this, the method is same as b18 non vtec, seeing as they are the same motor, b20 is simply overbored from the factory
extar oiling, extra cooling, and a TUNE IS A MUST
shortstopNE
Aug 12, 2012 04:30 PM
moskaEF9
Sep 26, 2009 08:19 AM
dokdok
Welding / Fabrication
Jan 26, 2009 01:22 AM
bLuBoOrEx89_RAZORS_
Dec 31, 2007 12:32 AM
rcdohc
Jun 15, 2007 11:10 AM
