Omni power throttle body question
Old Sep 1, 2010 | 04:17 PM
minilogoguy18's Avatar
Default Omni power throttle body question
I just got my omni power TB along with an S300 from phearable.net and before I put it all in along with my Euro R mani but I don't see a idle adjustment screw on here so I'm wondering before I go and try to do all this to my DD how would I adjust the idle? Thanks.
Old Sep 2, 2010 | 05:13 AM
Default Re: Omni power throttle body question
36 views and no one knows?
Maybe I'll ask the B series guys since Omni Power is popular with them.
Old Sep 2, 2010 | 09:15 AM
92civlude's Avatar
I bought a 70 mm from D&H racing with the same issue. I called them and they said "dont worry, it will idle fine" When I installed the TB with the basemap, it idled too low when warm. When I tuned the car, I gave the IAC more % when warm. Now it idles a 750 RPM.
Old Sep 2, 2010 | 12:56 PM
Rosko's Avatar
Theres usually an adjustment screw on the throttle rotor that you can use to change the blade's stop position and raise idle. Make sure you readjust your tps voltage if you move the rotor.
Old Sep 2, 2010 | 03:10 PM
^Yeah I figured this method as well as what 92civiclude said except the only laptop I own(actually my GF's) is a Mac and I don't think sManager works on Mac so I couldn't mess with the IACV %. Hopefully this Phearable basemap is good from the start, trying to avoid any downtime or running issues since it's my DD. Sorry for the simple question, just try to cover all my bases before I do anything.
CHANCELLOR12
Feb 6, 2016 03:46 AM
magicguy
Jan 30, 2009 02:00 PM
Spool This
10
Aug 3, 2008 01:25 AM
aasoccerplaya
Jan 9, 2008 05:24 AM
BigBlockCRX
Jul 30, 2003 03:31 PM
