CA REF Question: 96 Civic with 98GSR Engine.
Old Sep 1, 2010 | 11:57 AM
k20user's Avatar
Default CA REF Question: 96 Civic with 98GSR Engine.
Hey guys,
I have a question. My brother has a GSR which needs a rebuild (burning oil like crazy). Anyways I have a 96 civic with a JDM LS. Anyways..I wanted to ref the car with my brothers engine B18c1..since he recently passed smog..
I think I will pass to with all the oem parts in a 96 civic.
My questions is What harness do I need? Do I need a 96ex harness and is there any difference in the wiring "smog sensors" on the 96 Civic Engine and 98 GSR engines?
Thanks for all your help. Once I am done I will post a how I got my referee. So It will help others.
thanks!
Old Sep 1, 2010 | 12:06 PM
alacard's Avatar
Default Re: CA REF Question: 96 Civic with 98GSR Engine.
Unfortunately there isn't a harness that will just plug and play for your situation. The Integra harnesses were two pieces and won't work for a Civic. The EX harness will be your closest bet. You will have to extend a few plugs and you will also have to add a plug for the butterflies in the GSR intake manifold. You may have to switch a few wires around and/or add some more plugs. I can't remember.
As for the REF, you need to have all of the 98 gsr smog stuff (cat, charcoal canister, all evap hoses and sensors, etc.) in the car and working and you should be fine. Make sure you have a carb legal intake and header and if I were you I would print out documentation proving the legality (because I had a carb legal dc header and an AEM intake, and yet the guy STILL wouldn't accept them, I had to prove it next time around).
Here is a good source for the wiring:
http://technet.ff-squad.com/
Also search on HT for GSR wiring with a civic harness.
Old Sep 1, 2010 | 01:37 PM
k20user's Avatar
Thanks for the detailed reply. Looks like I will need to hunt the 96-98 harness down. Then just run the extra wires..
thanks.
Old Sep 2, 2010 | 10:14 AM
alacard's Avatar
thanks.
No problem man, good luck. It's really not that bad.
mr.k24
Jan 19, 2009 10:12 PM
96rear00nose
Apr 16, 2006 09:38 PM
s2k drifter
Aug 15, 2003 12:52 PM
