Car won't start NEED HELP!!!
Wsup guys?
I bought a 92 Prelude SI Automantic about a week ago and it ran fine love my new used car!!!!
Just last night i wanted to go to the store and it turned the key and it wouldnt start... So i turned the key to see if the fuel pump was kickin on and sure enough it wasnt. So i replaced it. I also replaced the spark plugs because the old ones were all corroded. So i tried to start it and it still didnt work. So i replaced the fuel filter because that coulda been the problem. But NO i was wrong. I try and start it now and all it does is crank... I sprayed carb cleaner in the intake manifold and it would start for a good 2-3 seconds and just die.
I can't figure out what it is so I though maybe one of you guys would kno...
Please help me out guys!!!!
Thanx!
Thanx!
make sure there is power going to the fuel injectors... I had the same problem. I replaced my fuel pump and it turned out that for some odd reason I had no power going to the injectors... check fuses and good luck
CRU
Sep 14, 2004 11:07 AM
