ALLMOTOR B-Series Part out!!!QUALITY PARTS INSIDE!!!
Parting out my All Motor B-series motor along with extra parts i have laying around and going a different route. All parts either have 12 1/4 mile passes on them or 6 dyno pulls it will be noted on the side of the item. Also all of the Skunk 2 parts are pretty much brand new with the pro-series valve springs, retainers, throttle body and composite fuel rail having the 6 dyno pulls and I still have all the boxes for the Skunk2 parts. I will sell stuff as a package if you like if you would like to keep stuff together. Prices do not include shipping unless noted. So here’s the list:
ECU:
Hondata s300 w/ p28 - $650
Engine:
Skunk 2 Pro3 cams-$500(has 12 ¼ mile passes)
Skunk 2 Pro series valve springs-$275(6 dyno pulls)
Skunk 2 B/H Dohc vtec retainers-$175 (6 dyno pulls)
Skunk 2 Pro series Black 70mm throttle body-$300 (6 dyno pulls)
Skunk 2 Pro Series cam gears-SOLD
Skunk 2 black composite fuel rail-$175 (6 dyno pulls)
Edlebrock Victor X GSR intake manifold Throttle body opening is ported to 70mm-$250 (6 dyno pulls)
RC 550cc injectors-$200 (12 ¼ mile passes)
Pauter 4340 rods for B18A/B one of the best rods you can buy -$650 (12 ¼ mile passes)PENDING
before getting installed
OEM LS 89mm crank PERFECT CONDITION-$150
Canton 15-962 steel “L” sump oilpan all b-series uses stock oem pick up-$250 (12 ¼ mile passes)
pan before use looks pretty much the same!
BARE 85MM RS Machines sleeved B18a block with a GSR girdle ARP mains and head studs comes with main caps -$700 (12 ¼ mile passes)
Six Sigma Racing custom side exit header-$800
Valve cover with -10 bungs for breather kit-$150
B&R polished breather kit with black -10 fittings and lines -$150 SOLD
Vtec solenoid-$40
GSR water necks with -16 bungs welded for AN fitting radiator setup-$60
Golden Eagle oil sandwich plate, line and fitting for vtec conversion-$100
Skunk 2 Black series billet wire cover-$120
OBD 1 alternator has been polished and in perfect working order-SOLD
Fluidamper B-series race series pulley pn=620601-$350 shipped
ACT streetlite flywheel-$175
ACT 4 puck sprung hub-$100
ACT Maxx extreme pressure plate-$100
JDM 98+spec ITR LSD transmission with ATS 4.9 final drive shifts perfectly-$1400
B-series axels-SOLD
half shaft-$60
GSR head parts (rockers, caps, rails, lost motion assembly) let me know what you need
Extra motor parts:
crower 95mm stroker crank-$500 brand new
Crower 4340 Steel billet rods for b18a/b-b20b-$400 pistons are not included (one is shot)
1 more 85mm RS machines sleeved b18a block with z10 girdle ARP Mains and headstuds this one for sure will need to be bored out to 86mm-$300 SOLD
Swap parts:
Innovative eg/dc solid motor mounts GOLD dipped done by SIK industries here in Santa Clara,CA-SOLD
DC rear T bracket also in GOLD dipped done by SIK industries -SOLD
ITR gold shift linage with prothane bushings and Skunk2 dual bend short shifter and Skunk2 shift ****-SOLD
That’s it for now I will get pictures up of everything as i start taking it apart. Prices are firm but all reasonable offers will be considered and please be reasonable…I spent the money for quality parts and so should you!
Email me for any questions 11secwkeg@gmail.com
ECU:
Engine:
Vtec solenoid-$40
B-series axels-SOLD
half shaft-$60
Extra motor parts:
Swap parts:
Pics of the engine mounts to Jordanwma53@yahoo.com
Dibs on the vtec noid...Would u sell this mount bracket that bolts to the block? The one with the studs going thru this one? Need one badly. lmk..I'll send the dough for both
