What can cause a sparkplug to bent
Old Aug 31, 2010 | 06:37 PM
GSREXMan's Avatar
Default What can cause a sparkplug to bent
Thanks for ur help.
Old Aug 31, 2010 | 06:52 PM
Hondatherdm's Avatar
Default Re: What can cause a sparkplug to bent
Just 1 cylinder? were any internal parts replaced, pistons, rods? were the head milled?
Old Aug 31, 2010 | 07:42 PM
Rok_Stok's Avatar
I know not.
Old Aug 31, 2010 | 07:49 PM
Bwill9886's Avatar
Hey the SER Spec-V is nothing to be ashamed of. My friend has one (In pieces now unfortunately) and I loved driving that thing. I think the newer ones kinda suck but regardless... still a quick car.
Anyway, Hondatherdm brings up some good questions. Sounds like something is hitting within the combustion chamber. Did they look at the pistons and/or the bottom-end when they checked out the head?
Old Sep 1, 2010 | 01:53 PM
alex95eg's Avatar
a lot of carbon on top the piston?
Old Sep 1, 2010 | 04:06 PM
megomaniac's Avatar
wrong spark plug for application
crush washer missing on threads of spark plug
to much timing/ lean condition causing extremely high cylinder pressures
foreign object inside cylinder
rod bearings so bad that the piston travels to high
bending it during install.. thats all i got
Old Sep 1, 2010 | 06:11 PM
fcm's Avatar
fcm
Old Fart
Ditto the above ^^^.
Look at plug tip protrusion... http://en.wikipedia.org/wiki/Spark_plug 94
Old Sep 1, 2010 | 06:26 PM
GSREXMan's Avatar
Well it bent it the ones i got from autoparts so my mechanic went to nissan and got ngk spark plugs for my car. After a test drive the plug in cylinder 1 was close as if something had close it or hit it. So after that i got a honda spark plug witch is almost half of the nissan but it still got bent so i dont know wat alse i can do. This is just happenig in cylinder 1
Old Sep 2, 2010 | 05:58 AM
fcm's Avatar
fcm
Old Fart
Add a second washer to the #1 cylinder spark plug and see what happens.
It is beginning to sound like there is some other problem, excessive carbon build up on the #1 piston maybe or maybe an improperly machined head, [flat but not level], maybe even the wrong piston or rod.
I can't see it being anything worn out, [wrist pin or bearing] as that should be noticeable with engine running.94
Old Sep 2, 2010 | 07:45 AM
alex95eg's Avatar
sounds like you have excessive carbon on top the piston bore scope the engine
http://www.harborfreight.com/wireles...tor-66550.html
this tool can be ur best friend!!
Old Sep 2, 2010 | 08:38 AM
Bwill9886's Avatar
Originally Posted by alex95eg
Indeed, if you can find a place/person that would rent one out/let you use it for a bit you could look right in and find out for yourself!
Old Sep 2, 2010 | 04:36 PM
GSREXMan's Avatar
Well its sucks case my car has some problems like the butterfly srews tend to get loose and go inside the head and cause distruction and a pre-cat in the header mey cause the motor to go out so to get that out of the way im runing my vin # with nissan to if my car is one of the bad sentras out there if it is i would be in luck case they would have to fix it or even replace the motor at no charge. Thanks for all ur help guys i knew the honda family would help
Old Sep 2, 2010 | 09:15 PM
Bwill9886's Avatar
Yeah I know what you are talking about with the pre-cat, among other things. There's no doubt some of these cars had issues. My friend has experienced just about every single one in his 2002.
Good luck with yours man.
Old Sep 3, 2010 | 11:21 PM
lopex's Avatar
My guess is that it was bent when he put it in.
____________________
Vlc Player Download
Old Sep 4, 2010 | 08:13 AM
Bwill9886's Avatar
He is saying that all the spark plugs he has put in cylinder 1 have all bent one way or another. Not just one.
Roy Leyva
Engine Management and Tuning
14
Jul 8, 2017 02:08 PM
azn209
Jan 8, 2014 11:06 PM
TravisBiggie
Sep 29, 2013 06:33 PM
jelcivic
Dec 12, 2012 05:21 PM
auto_destroyer
Aug 10, 2002 08:36 PM
