B-Series LS/VTEC Turbo - Complete Partout - KS
I have 2 P28 ECUs. The first one is an automatic ECU. I bought but never ended up removing the couple things to make it a 5 speed ECU (I just put added VTEC to my ECU).
The second one is Chipped, although unsuccessfully. I believe it still works as a stock P28. The solder was not done cleanly, so that could probably be cleaned up to make it work correctly.
Unorthodox Lightweight Flywheel - I believe one thread was re-tapped or helicoiled. I can check the threads if you're curious. $175
Stock flywheel
B18B / LS Valve Cover (not pictured) - $??
K&N Air filter (pretty much normal size, but I can take measurements)
FUEL SYSTEM
Water injection w/ pressure detection (aka clogged nozzle indicator) & purge $180
Bosch Oxygen Sensor - P/N: 3737 (not pictured) - Used for about 5 minutes $55
SUSPENSION
Front Strut tower bar for DC Integra - Pic needed $60
Nitrous
Zex dry nitrous kit w/ 55, 65, and 75 shot jets (Zex sells a wet conversion if you want a wet kit) $220
Bottle heater $50
Interior
Carbon fiber ebrake handle
A-pillar gauge cluster
autometer AFR (air fuel ratio) meter $30 for gauge, or $40 for a-pillar
Electronics
GTech performance meter
two sets of nice speakers (~$75 MSRP speakers)
Several head units
Stock parts
Stock intake parts
Stock Injectors (not pictured)
Stock LS Cams (not pictured)
Stock LS and Stock GSR intake manifolds
Stock flywheel
FUEL SYSTEM
SUSPENSION
Nitrous
Bottle heater $50
Interior
Electronics
Several head units
Stock parts
Stock intake parts
LONGBLOCK BUYER FELL THROUGH -- I'll re-add the info about it soon, but it's a GE sleeved block with 9:1 CP pistons and eagle rods
