good cam for my b20v
ive been piecing together this motor for a few years out of spare parts and the only thing i dont really have are cams. cars purpose will be to take out on weekends when my turbo car is inevitably down for some reason. not looking for crazy power just good driveability. will be dyno tuned on neptune
b20 84.5mm
oe rods w/arp bolts
rs 11.5 itr pistons
arp headstuds
(ill swap in the 22t water pump as well)
the block was already run as a b20 nonvtec for a year. motor turned over 240psi with 5% leakdown. its got 17k miles and the crosshatch looks mint still, so it should be good to go. i never revved it over 8k with the oem ls rockers
head is a b16.
skunk2 pro series im
blox 72mm tb
oe itr dual springs
brand new bc steel retainers(or some used omni ti retainers i have lying around also i havent decided)
full race camgears.
i guess ill only look to spin this thing to around 8500. i had the itr springs in my boosted motor for a year going to 8700 no probs.
i was thinking something in the range of blox b's or skunk tuner 2's.
can i run the pro 1's with that valvetrain if i keep the rev limit reasonable?
b20 84.5mm
oe rods w/arp bolts
rs 11.5 itr pistons
arp headstuds
head is a b16.
blox 72mm tb
oe itr dual springs
full race camgears.
you might get away with blox a's or s2s1's but you might not either. i would just replace them!!! supertechs are cheap enough....no sense in trashing a motor for a part thats under 200$
thinking about itr's. i have them in my turbo motor which i might get something bigger for and then use the itrs for the all motor setup..
also ive got rc 310's. am i going to run out of injector??
Hell no, you will be fine. Kill two birds with one stone, your turbo car will benifit from a nice cam upgrade and so will your b20v.....
BTW Im jealous, I would love 2 fast hondas, one n/a one turbo.... Well done Sir... Well done!
213whp would be more than fine for what i'm looking for, but my compression would be just about 12:1 flat.
is your buddy still running pump gas?
popwars123
Sep 19, 2008 06:14 PM
tim_adams85
Apr 1, 2006 11:12 AM
