What is the 3rd pressure switch failure?
Old Aug 31, 2010 | 10:51 AM
andhoova's Avatar
Default What is the 3rd pressure switch failure?
It is returning that error code on my 2000 accord. Do I need to replace this immediately?
thanks
Old Aug 31, 2010 | 08:12 PM
phootbag's Avatar
Default Re: What is the 3rd pressure switch failure?
Your vehicle may enter a default shift pattern because of this DTC. You should be able to still drive the car. However, diagnosing the problem is important.
In my experience the switch itself is usually the culprit. The switch is confirmation that a shift has occured and clutch pressure can be released from the previous gear.
You can replace it yourself. No ECM programming or anything required.
Old Aug 31, 2010 | 10:21 PM
toomtoomvroom's Avatar
I had the same code, i ended up picking up the switch from ebay for $45 and had my mechanic install the unit. I also did a drain and refill for the tranny.
Old Sep 1, 2010 | 01:27 AM
HondaPartsHero's Avatar
Technical Hero
if you decide to replace it here's a write up for a similar model:
http://tl.acurazine.com/forums/showthread.php?t=729149
and a picture of where it is:
ZamboniDude
Acura TSX
Jan 20, 2019 03:40 PM
lcommisso
Dec 10, 2018 09:13 AM
Bigskyguy
Nov 20, 2017 03:54 PM
Moe Grant
Aug 30, 2015 12:56 PM
santhon2
Dec 17, 2010 06:13 AM
