99-00 Si........What are you launching at?
Old Sep 17, 2002 | 09:04 PM
ProEater's Avatar
Default 99-00 Si........What are you launching at?
Just like it says... lemme know what your launching at if your are mostly stock or still stock. Ive been launchin at 3k-3500 on the street with street tires, tried a few other launches but i not sure what everyone else is launching at? thanks in advance....
-Ian
Old Sep 18, 2002 | 09:08 AM
SmobbinSi's Avatar
Default Re: 99-00 Si........What are you launching at? (ProEater)
Civic EX Firestone stock tires inflated to 30psi, I am launching at 5.0-6.0k and getting 2.3ish 60fts on a good launch...the car is bone stock, not even I/H/E.
Old Sep 18, 2002 | 11:35 AM
ProEater's Avatar
Default Re: 99-00 Si........What are you launching at? (SmobbinSi)
so maybe i should launch a little higher? are you dropping the clutch or feathering it
thanks
Old Sep 18, 2002 | 01:33 PM
h huff's Avatar
New User
i'm running nitto 555r's on 14 inch aluminum acura rims at 25 psi. my 60 ft time average is a 2.1. i hold the rpms at 5500 and feather the clutch. the car still spins but if it doesn't stuff breaks. anyhow that's what works for me
Old Sep 19, 2002 | 08:54 PM
visi0n's Avatar
Default Re: 99-00 Si........What are you launching at? (h huff)
I launch at like 5k...but when the tires start gripping more i launch a tad higher. This is on street tires. Oh i usually don't go full throttle till it grabbs. This is with i/h/e/cams.
Old Sep 19, 2002 | 09:04 PM
Suprdave's Avatar
Lower the pressure down to like 18psi, then do a really good burnout and smoke them up nicely...launch at around 6000rpm
Suprdave
B18CR-X
Sep 11, 2003 01:57 AM
BauleyCivic
Aug 14, 2003 10:10 AM
ridnmyhonda
Jul 23, 2002 12:36 AM
Unsung
Jun 7, 2002 11:41 PM
ezark
Nov 15, 2001 09:53 AM
