B&M fuel pressure PSI for b16
only way to really do it right is to get the car on a dyno with a wideband O2 and tune it to a good air fuel ratio. 14.7 parts air to 1 part fuel is the ragged edge of detonation, a 13.5 is a good ratio.
40 PSi with the vaccum line attached was too much for my car. I dropped it down to 37 and gained 1 hp on a dynojet. I have aftermarket chip which dumps mucho fuel at high rpms.
[Modified by Phat_Optimo, 4:51 PM 9/18/2002]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thagreybomber »</TD></TR><TR><TD CLASS="quote">bump...cause I'm having the same problems
yep, me too. I failed e-check twice with WAY too high NO levels with what i have seemed to find out means i am running too lean, right? so i am considering an adj. FPR to bump up the fuel a little to compensate for my i/h/e. is this a good idea? should i have had an FPR on all this time?
</TD></TR></TABLE>yep, me too. I failed e-check twice with WAY too high NO levels with what i have seemed to find out means i am running too lean, right? so i am considering an adj. FPR to bump up the fuel a little to compensate for my i/h/e. is this a good idea? should i have had an FPR on all this time?
spoon_r_951
Aug 8, 2006 10:01 PM
spoon_r_951
Aug 8, 2006 10:00 PM
b16vtecsol
Jan 2, 2004 01:15 AM
