prelude cluster wiring help
i installed 97 prelude cluster in my 96 accord coupe but have srs and abs cel on. no codes but lights are on-anyone have pin numbers maybe different from the 4door install. hope someon can clear up for me thanks peeps
nobody has idea what pins for accord coupe for srs and abs. i used the diy guide but lights are on, any help pls so i can use the cluster
thanks for the info -finally got some time to check around- i had to reset srs on the lude cluster- now srs is out- still cant figure out abs and illumination on right side is off- going to check dmmer switch and relay- was hoping i'd have this thing running- got the
h22 swap almost ready to dropin.
for those wanting to do the lude cluster on a 96 coupe- the lude write up is correct but i'll add some more info- you need to attach the other red/blk wire for illumination and add the other red wire for brightness. this will enable to make your whole cluster light up. will add more info as soon as i figure out why abs light is on. i think it has to do with alternator/battery sensor....
Allmotor2.3
Jun 15, 2015 07:10 PM
utturkey
May 25, 2011 05:42 PM
