d15a3 head swap with f22b2
Old Aug 30, 2010 | 09:44 PM
honda361's Avatar
Default d15a3 head swap with f22b2
i have a 87 crx si motor i am plannin on putin the motor in my 90 crx hf but i wanna know if my f22b2 soh head will fit on my d15a3 soh motor....o and if u know were i can get performance parts for the d15a3 motor that would help alot....
Last edited by honda361; Aug 30, 2010 at 09:53 PM. Reason: forgot to add some info
Old Aug 31, 2010 | 12:48 PM
jlk16188's Avatar
Default Re: d15a3 head swap with f22b2
NO, 1.5 and 1.6 SOHC heads swap pretty easily, wont fit at all...sorry about your luck
Old Aug 31, 2010 | 01:42 PM
crx_si-r's Avatar
Did u miss the fact that he wants to put a f22 (2.2l sohc head) on a d-series motor?
No you cannot swap the f-series head on your d-series motor.
Old Sep 5, 2010 | 05:18 AM
jlk16188's Avatar
no i obviously didnt miss the fact that hes trying to swap an accord head on a d series, hence why i said that it wont work at all...thanks for reading plain english buckwheat
Old Sep 5, 2010 | 12:06 PM
jlicrx's Avatar
also, the D15A3 engine is not going to bolt into the 2g CRX - different mounts and won't bolt to 2g transmission
Old Sep 5, 2010 | 02:45 PM
J_Marc's Avatar
Like it has been said above you have a 90 crx hf, you can't swap in a powertrain from a pre-88 crx. You can't use any f-series parts on you d-series. Your car is an hf, I'd suggest getting a swap out of a 90-91 Si, put that in you car and call it a day.
Old Sep 5, 2010 | 06:41 PM
mattliston's Avatar
Only head swap available for the d15a3 is teh dual cam head form the integra's d16a1
its called a HYDRA
Look it up.
More power, slightly better compression, better gasmileage, MORE F"UN!!!!!
DO IT *****A!!!!!
gimme that F22 though, I wanna experiment with it!
lol
boostedteg1203
Feb 23, 2010 09:59 PM
95CivicDx51
Jul 16, 2008 08:30 PM
97LXecutioner
Feb 18, 2004 08:35 PM
Camera Car
Feb 18, 2004 05:04 PM
