Determining LSD
Old Sep 17, 2002 | 08:22 PM
EF_LSVtec's Avatar
Default Determining LSD
Without the stamp of LSD on tranny...If you peek through where the axles mount to the tranny, my mechanic pointed a small metal cylinder bar that goes accross the inside visible on both ends. Anyway, he says, with bar=non lsd, without bar=lsd...is this true? Another Q, if you turn either axle attached to a tranny and the opposite axle turns also, does it mean it has lsd?
Old Sep 17, 2002 | 08:31 PM
bryant's Avatar
Default Re: Determining LSD (EF_LSVtec)
your mechanic is correct
Old Sep 17, 2002 | 09:58 PM
the DR.'s Avatar
Default Re: Determining LSD (CR-X)
if you have both axles out, if you're able to see all the way through to the other side, you have lsd
i ..think.. if you jack the car up (front wheels of course) put the trans in NEUTRAL, spin one tire, if the other tire spins the opposite way, you have lsd.
of the car is IN GEAR and you spin one tire , i think the tire will spin the same direction with lsd.
please correct me if i'm wrong
Old Sep 17, 2002 | 11:02 PM
spettinger's Avatar
Default Re: Determining LSD (CIVICtypeS)
not sure on the tire spinning issue, although it makes sense. because the lsd locks the spider gear in a sense, in neutral one wheel should move the other. as for looking through the diff, no bar means LSD baby.
Old Sep 17, 2002 | 11:13 PM
Lamchop0000's Avatar
here you go buddy
when are you going to post pics with that radiator clearance for the place racing X-member. so i could see if a 92+ half size raditor will fit
[Modified by lamchop0000, 12:14 AM 9/18/2002]
Old Sep 18, 2002 | 06:41 AM
APEXI Si's Avatar
Default Re: Determining LSD (lamchop0000)
Is that true with aftermarket lsd as well.
I bought a car, and the guy said that he had lsd put in it, but hte bar is still there.
so what dose that mean.
Old Sep 18, 2002 | 07:38 AM
ijjz's Avatar
Default Re: Determining LSD (crx616)
I would think LSD is LSD, nothing else to it. So you probably got lied to.
Old Sep 18, 2002 | 08:08 AM
loclowd's Avatar
Default Re: Determining LSD (ijjz)
^^^ is probaly right, is this a good friend you bought it off of, or someone that you met at a show or on the net?
Old Sep 18, 2002 | 08:20 AM
EF_LSVtec's Avatar
Default Re: Determining LSD (dee-ecks)
I wasnt really lied to. The tranny was given to the person whom I bought it from and claimed it had LSD. Paid $400 but there's a crack on the housing. I drove 100 miles one way to pick em up 2 weeks ago. I took it to my mechanic yesterday and he pointed out the fact that its not LSD. I called the person I bought it from and he was as surprised as I was and offered to refund my money. Cool guy, except now I have to drive it back...I thought I'd post a thread just to confirm...Thanks fellas
Old Sep 18, 2002 | 09:12 AM
spiceisler's Avatar
As far as RWD cars I've owned, when I spun the wheel on one side of the car, the other wheel spun in the same direction indicating that it was indeed LSD. I will safely assume then that the same goes for FWD. <U></U> http://groups.msn.com/ClassicMinis
[Modified by clean90Si, 1:15 PM 9/18/2002]
Old Sep 18, 2002 | 09:47 AM
Home Skillet's Avatar
put it on your tongue for 10 min, wait one hour. then you'll know if it's lsd.
Old Sep 18, 2002 | 09:48 AM
EF_LSVtec's Avatar
Default Re: Determining LSD (Home Skillet)
I did that bro..but my butt started to tingle, then i thought of you
hahaha...
Old Sep 18, 2002 | 10:03 AM
hahaha...
hmm, i'm not even gonna ask
Old Sep 18, 2002 | 10:05 AM
EF_LSVtec's Avatar
Sorry about that non-sense remark folks... Eye for an eye..
Old Sep 18, 2002 | 10:06 AM
ijjz's Avatar
lol
Old Sep 18, 2002 | 10:54 AM
johnzm's Avatar
if you put it in first gear, the tires will wpin oppisite each other.
Old Sep 18, 2002 | 10:59 AM
EF_LSVtec's Avatar
Default Re: Determining LSD (johnzm)
You mean, if its in gear one goes forward and other goes backwards?
deathofadam
30
Jun 15, 2007 05:13 AM
gunnis
Sep 8, 2005 07:53 PM
98oRange
Apr 8, 2005 06:45 PM
LSegHatchy
Oct 28, 2004 12:20 PM
Wrath of VTEC
Dec 1, 2003 12:04 AM
