body filler recommendations?
Old Aug 30, 2010 | 12:46 PM
mish__'s Avatar
Default body filler recommendations?
Trying to prep my car for paint and i have tiny dings. any body filler recommendations?
Old Aug 30, 2010 | 03:15 PM
rxbahamut's Avatar
Default Re: body filler recommendations?
I would just stick with Bondo it is one of the cheapest. I like the fiberglass filler it seams to be stronger.
Old Aug 30, 2010 | 04:56 PM
Spawne32's Avatar
bondo is horrible walmart brand filler, stick with evercoat products and you will be golden
Old Aug 30, 2010 | 05:53 PM
DC2.2_GSR's Avatar
/\ ignore this post.
like Spawne says, Evercoat. I prefer the Evercoat Rage Xtreme, but the standard Rage is also very good.
Old Aug 30, 2010 | 07:24 PM
rxbahamut's Avatar
I like Evercoat too. But about Bondo look on the website they are made by 3M now they are basically the same as the 3M product. I think they bought them out years ago.
Old Aug 30, 2010 | 07:33 PM
Spawne32's Avatar
despite the fact that bondo is made by 3m, it is still a terrible product, ask anyone who does any body work proffesionally
Old Aug 31, 2010 | 03:11 PM
DC2.2_GSR's Avatar
when a company buys out another, it's not with the intent to change their product. they buy them out with the intent to not change a thing, and collect the profits under the same name using the same product. 3M didn't buy Bondo brand and then change the Bondo formula and ingredients to 3M stuff, they bought the brand name and made no changes except to their bank accounts.
Bondo brand fillers are complete garbage. No matter how you knead, flip, and press you can't ever 'mix' out the air pockets. no matter what brand or grit sandpaper you use, you'll use twice as much sanding Bondo. no matter how nicely you apply it and how well you prep the surface underneath, you'll never get Bondo to chemically etch into the metal and provide any corrosion protection.
if you'd rather save $10-$20 on filler, buy Bondo and spend that on the extra sandpaper and extra time required to fill pinholes and re-spread more filler and re-sand everything, and spend more money next time you have to make the same repair because the Bondo cracked out because the underlying surface corroded.
forget the Wal-Mart and Advance Auto Parts way of doing body work, and go buy a can of a good Evercoat filler and a tube of USC Icing and research proper filling and skim-coating techniques... do it the way the pros do.
Old Aug 31, 2010 | 03:28 PM
gorillafart's Avatar
evercoat. holler at yo girl
Old Sep 1, 2010 | 09:41 PM
EGcivic_95's Avatar
bondo does suck lol, i usually use "filler from the future" its works good does what its intended to do im happy with it
Old Sep 2, 2010 | 06:31 AM
jksmith's Avatar
EVERCOAT RAGE ftw !!
Old Sep 4, 2010 | 05:37 PM
adam ef's Avatar
yeah rage extreme is amazing ****, im currently using it and its so awesome.
Old Sep 5, 2010 | 03:28 PM
shocker911's Avatar
evercoat with BLUE hardner...**** RED HARDNER
Old Sep 8, 2010 | 08:09 PM
dem0nk1d's Avatar
EVERCOAT!!!! Also if you really want a pro opinion check with your local autobody shop supplier, or autobody shop. Also something i read with the Red hardener is that some times it has a tendency to bleed through.
Old Sep 11, 2010 | 11:58 PM
jdm Ef-9's Avatar
rage or evercoat are both great products. but as anyone will tell you, try to use it as little as possible. if you can tap it out, panel replace or pull it, do so. do not make the mistake on filling rotted quarters with 1/2 gallon of mud.
sticking to these tips will make your work last a hole lot longer.
Old Sep 12, 2010 | 06:49 PM
shocker911's Avatar
i also shrinks more then filler with blue hardner
Old Sep 12, 2010 | 11:22 PM
jasoncrashtech's Avatar
rage , spot lite, metal glaze. good products
amrussellusn
Paint and Body
Oct 7, 2012 03:13 PM
EM1 Resto
Paint and Body
25
Jan 10, 2010 02:50 PM
-16V-
Paint and Body
Mar 15, 2009 06:35 PM
GroundZer0 336
Aug 13, 2003 01:12 AM
Big Ed
Jan 15, 2002 10:34 PM
