A/c in crx with b16
Old Aug 29, 2010 | 11:17 PM
fatCRXguy's Avatar
Default A/c in crx with b16
So i have a b16 in my crx. if i have the b series a/c bracket and a b series a/c compressor, both are off a 97 GSR. can i hook up my stock crx a/c lines and have a/c?
thanks for the help.
Old Aug 29, 2010 | 11:33 PM
crx_si-r's Avatar
Default Re: A/c in crx with b16
Not without modification. You need an a/c conversion bracket to fit a d-series a/c compressor in a b-series swapped 88-91 civic/crx
Old Aug 29, 2010 | 11:41 PM
hatchet_honda's Avatar
if you woulda tried this out before asking you woulda seen that no..it wont work. the stock ac lines from the rex wont fit the new compressor. as stated you need the swap bracket to fit the d series compressor on the b series block.
Old Aug 29, 2010 | 11:42 PM
fatCRXguy's Avatar
bummer dude, i dont have either of those things. thanks for the help though.
Old Aug 29, 2010 | 11:43 PM
fatCRXguy's Avatar
What if i get the lines from the integra. would the fit in the crx?
Old Aug 29, 2010 | 11:48 PM
well the compressor ends will yes. but they will be the wrong length/size... custom ac lines could be possibly made, but the ac swap bracket is the easiest route
Old Aug 30, 2010 | 07:56 AM
wheelgarage's Avatar
I'd say, go to the local pick-n-pull and see if they all work....free of charge! Well, maybe $2.
Old Aug 30, 2010 | 04:58 PM
slywfbpsi's Avatar
just get a hasport a/c bracket, it will alleviate alot of the headache.
typac69
May 3, 2009 07:40 AM
661rex89si
May 1, 2007 11:07 AM
higgunscrx
Aug 14, 2006 12:38 PM
PassThatShi7
26
Jul 18, 2006 03:12 PM
Turb0Minnow
Dec 22, 2002 06:55 PM
