89 crx swap d15b7(it had d15b1) (i needs help)
just put in the d15b7 and used my wireing harness and my dist. and my intake manifold i need to know where i can get a custom motor mount and i need to know if ill have to find me a ecu...?
use the motor mount off your old engine.
now since you are using the dpfi intake off of the b1 you might be fine using the b1 ecu to run the b7. if it doesn't run right then i would suggest swapping to a mpfi manifold and running it either off an odb0 pm6 or converting to obd1 and using a p06
well i got it to start once with me adding fuel to the intake manifold and it started once and i know now its getting fuel now that i put some gas in the gas tank because i was on e .. but it still doesnt want to start up easyley i guess its not geting enough fuel presure or something
the d15b1 and d15b7 motors are the same exact block
the heads use teh same stuff to bolt together
use your d15b1 crap on teh d15b7 block and head
nothing difficult
nothing difficult
i did use everything from the b1 on the b7 because when i went to upullit in new orleans to get the block it didnt have alot of stuff on it ... it was just the block, head and intake manifold
sounds like you are missing an engine ground probably the thermostat ground and also check the grounds attached to your engine, block and frame.
well you was right about the thermostat ground i had forgoten to bolt it up and well it started right up but i have some more problems i got to workout... like i need to know whats the different hoses go to that are behind the thermostat housing and when i get my next check i got to get a o2 censer and cluch cable ...
Ive been thinking about swapping out my old b1 for a b7 from what I can comprehend from here is that I can use my b1 wiring, hoses, manifolds, ect. all I would need is the b7 block and head correct?
2point3h22lude
Jun 10, 2005 05:23 PM
