Freaking WHEEL STUD HELP!
Old Aug 29, 2010 | 03:20 PM
HondaKing90's Avatar
Default Freaking WHEEL STUD HELP!
Im trying to replace a broken wheel stud in a 00 civic and that **** just wont come out there isnt enough room for it to come out so how the fck do i change it help!!!
Old Aug 29, 2010 | 03:28 PM
Canuck99's Avatar
Default Re: Freaking WHEEL STUD HELP!
Front or Rear?? If its the rear pop off the wheel bearing and hammer it out, if its the frt pull the brake rotor off hammer it out, if its hitting the spindle you can sometimes get away with loosining the axle nut and pull out the hub a bit and slide it out
Old Aug 29, 2010 | 03:31 PM
CrAzE191st's Avatar
second that
also if its too long, cut it down shorter if necessary
another tip when putting a new one back on, grind the side of the bottom part of the stud a little so u can slip it in without having to remove the hub
Old Aug 29, 2010 | 04:29 PM
yea i tried removing the hub **** dnt come out... but i did think of an idea lmk wat you think what if i grind down a part of the spindle on one side enough so i can jus pop out the stud through there n ill jus rotate the broken stud over to that side n jus pop it out through there???
Old Aug 30, 2010 | 03:12 AM
Canuck99's Avatar
Could do that, cant picture in my head the amount of clearance, shaving the stud like suggested is ok...You need a slide hammer to pull the spindle out a bit...you could also just cut the top off the old one to remove it and then decide how to get the new one in after..
Old Aug 30, 2010 | 09:20 AM
yea i was thinking maybe i cut off the top of old one and then the new one shave it down so that it fits through the spindle ?
but idk which idea sounds btr the spindle one sounds a bit easier? lol
spoon.ef9
16
Jan 25, 2012 04:18 PM
ewoo
Feb 24, 2009 04:23 PM
Pompiuses
Sep 12, 2005 06:57 AM
classciv
Aug 27, 2004 06:24 PM
