obd0 to obd1: can i keep my obd0 injectors?
Old Sep 17, 2002 | 07:31 PM
ShiroX's Avatar
Default obd0 to obd1: can i keep my obd0 injectors?
i did a search and blown hatch said that its possible to use the OBD0 injectors as long as I keep the Inject restistor box
is this really true?
How would wiring work?
Old Sep 17, 2002 | 08:03 PM
Tbone's Avatar
Default Re: obd0 to obd1: can i keep my obd0 injectors? (VTeC4TheChildren)
Yes it is , I run 370cc peak hold(obd 0) in my crx which is converted to obd 1 . I actually use one of blown90hatches conversion harnesses too. just like he said, leave the resistor box in. You wont have to change any wires.
Old Sep 18, 2002 | 05:10 AM
ShiroX's Avatar
Default Re: obd0 to obd1: can i keep my obd0 injectors? (Tbone)
if this is true, then what all would i need to change then?
just the wiring on the dash side? and run some wires out to the engine?
I have a y8 head will I need the z6 distributor? If i need z6 dizzy i will have problems bolting that to my head correct?
how much is blown hatch harness btw
Old Sep 18, 2002 | 08:59 AM
Tbone's Avatar
All you will have to do to use his harness is plug it in and run a few wires to the engine bay for the 4 wire o2, vtec, and knock sensor.(if you have those things) And then repin your distributor. As far as you y8 ? I havent touched a single cam in 5 years so I'm a little rusty as to what distributor you need
Old Sep 18, 2002 | 11:36 PM
Giuseppe's Avatar
now...why would blown90hatch lie to ya.???
have faith.!!
Old Sep 19, 2002 | 04:44 AM
crxman00's Avatar
is there anyway to get in touch with blownhatch? I need that odb0 to odb1. Conversion too. Thanks
Old Sep 19, 2002 | 04:57 AM
Tbone's Avatar
Default Re: obd0 to obd1: can i keep my obd0 injectors? (crxman00)
Just IM him "blown90hatch"
Old Sep 22, 2002 | 07:42 AM
Blown90hatcH's Avatar
The harnesses are 170 shipped in the states. The EF plugs have gotten so scarce right now it is hard to find them. You will need a 4 wire O2 sensor, OBD1/OBD2 distributor and an OBD1 ecu. The injectors are optional. Let me know via email or IM
Turbo_EK@yahoo.com
Jason
deltazlt
May 26, 2013 09:56 AM
killerken25
12
Feb 6, 2012 12:04 PM
jdub01
Sep 11, 2007 10:32 PM
JDM_EK_JOE
May 2, 2006 08:47 PM
Renegade
Oct 30, 2003 07:22 AM
