putting directional tires on the wrong side cause drifting?
Old Aug 29, 2010 | 02:40 PM
komat's Avatar
Default putting directional tires on the wrong side cause drifting?
so i lately i been trying to figure out why my car pulls to the left. i swap out the whole driver side suspension with new parts. and it still pulled to the left.
so i decided to cross swap the front tires. now the car drifts to the right not pull . will directional tires not facing the right way affect the car pull/drift left or right
Old Aug 30, 2010 | 02:11 PM
TunerN00b's Avatar
Default Re: putting directional tires on the wrong side cause drifting?
No.
However, running directional tires the wrong way will absolutely kill wet traction.
Old Sep 3, 2010 | 07:14 AM
nsxtasy's Avatar
H-T Order of Merit
Correct.
Drifting to one side is not caused by the tires going in the wrong direction. It's possible one of your wheels is bent, or your car may need an alignment. If you (or a friend) have another set of wheels and tires known to be good, that you can swap onto the car, that would isolate the problem to either the wheels/tires, or the car's suspension.
joseapg1
Honda Civic (2006 - 2015)
Nov 10, 2015 07:28 AM
wtsapexipowerfc
Apr 27, 2011 07:26 AM
EJ1 wilcox
Suspension & Brakes
Feb 28, 2006 06:27 PM
sshaikh01
23
Apr 7, 2003 06:20 PM
Log4n
Feb 9, 2003 06:09 PM
