Heater core
Looped or plugged, blocking the path to the heater core will not affect the cooling system's performance. Your heater core is essentially a small radiator, so the cooling capacity is decreased slightly, but if the rest of your cooling system is in good shape there is no need to worry.
I have to loop mine because one of the copper inlet tube is slightly bent causing a slow drip/leak.
Replacing the heater core takes little mechanical skill, but a lot of time, as it requires removal of the dash.
Kyles ej1
15
Jun 29, 2005 05:17 PM
scratchline20
Jun 21, 2003 08:29 AM
