WHEN to go with oversized intake valves!!on boost...
Old Aug 29, 2010 | 01:34 PM
cibao2ner's Avatar
Default WHEN to go with oversized intake valves!!on boost...
1st the cams
so im about to send my head to get ported and ive been told to used 1mm oversize intake valves...those are the specs of the cams im using on ferrea rollers..ive seen 900hp claiming on stock ports...i would rather not used oversized but if i must i will...just looking for opinions....aiming for 900+whp...using 9:1 compression 84mm block..and a magnus im...maybe the pros will chime in...
Old Aug 29, 2010 | 01:58 PM
narfdanarf's Avatar
Default Re: WHEN to go with oversized intake valves!!on boost...
I have .5mm o/s valves intake and exhaust and I regret it, especially when I told my head porter than I absolutely did not want o/s valves.
Old Aug 29, 2010 | 06:27 PM
cibao2ner's Avatar
thats what im thinking if the flow thats gain is worth the clearances and tuneability you loose...
Old Aug 29, 2010 | 06:35 PM
Ineed$'s Avatar
I think RLZ put an end to this discussion after honda day when they went into the 8's with standard sized valves
Old Aug 29, 2010 | 07:00 PM
cibao2ner's Avatar
yea i got my answer already...not worth it..
rmcdaniels
Jan 31, 2008 05:19 PM
Pandahatch
Jan 25, 2008 02:53 AM
sup3rd
Nov 26, 2007 06:30 PM
RACEPAK
Oct 2, 2005 03:57 PM
untuned
Apr 7, 2004 03:00 PM
