OBD2A TO OBD1, MAIN RELAY CONSTANT TICKING
Old Aug 29, 2010 | 11:44 AM
dturbo's Avatar
Default OBD2A TO OBD1, MAIN RELAY CONSTANT TICKING
Vehicle is 96 civic cx. Engine harness came out of a 96 civic EX. d16z6 motor.
Re-pinned dizzy.
Went to go turn over key and main relay just constantly ticking. Doesnt stop. Found the IAC also clicking. Unplugged IAC and then fuel pump primes and ticking goes away. Turned over vehicle and fired up for a split second. Plugged IAC back in and does the same thing. After a couple attempts I just left IAC unplugged.
Now after about 10 attempts to start vehicle, car does not have enough spark. Swapped dizzy with known good dizzy and still no spark. IAC still unplugged. Noticed that once key is turned, the MAIN relay stays clicking for a bit.
Installed new known working relay, still same problem.
I am very confused, checked diagrams and lead to nothing. Any ideas?
Old Aug 29, 2010 | 11:49 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: OBD2A TO OBD1, MAIN RELAY CONSTANT TICKING
Check all your grounds on the engine/transmission/frame
Old Aug 29, 2010 | 12:29 PM
dturbo's Avatar
Thanks HONDAPARTSHERO! You are my HERO! Bad thermostat housing ground. Peeled off grounds and found corrosion. Repaired and THE BEAST LIVES!
Brand
21
Sep 8, 2022 09:39 AM
ckirso
Mar 18, 2013 08:08 AM
sohctodohc
41
Sep 9, 2010 04:06 PM
ef-hatchcrap
Mar 9, 2010 06:37 PM
MonkeyPuzzle
26
May 25, 2009 09:15 AM
