91 Accord - ALB control lamp flashes - Module makes weird noise
I've got following problem on my 91 Accord Sedan:
After I started the engine and drive a few seconds the ALB control lamp starts glowing.
Sometimes, the lamp stays off but then the ALB module makes weird noise, sounds like pumping and when I step on the brake pedal for more than a few seconds the pedal vibrates a few times back and forth....very strange & unsafe feeling.
After I turn off the engine and start again, the ALB lamp glows again.
I already tried to bypass the small blue 2-pin connector under the passenger's side dashboard and check the control lights, without success. Nothing happens....
Anyone an idea?
I already cleaned the wheel sensors & the axle ALB rings.
Anyone an idea?
hookups214
Jul 21, 2008 11:41 PM
Flatland2D
May 30, 2007 05:59 AM
