Montana D16z6 build back to life!!!
Old Aug 28, 2010 | 09:49 PM
dyno76's Avatar
Default Montana D16z6 build back to life!!!
Hello all! Thought I would post in here since I finally am hoping to run the 1320 again one day..Been away from the Honda scene for couple years came back slowly couple months ago but now I am back in all the way..Probably ask alot of questions hope you guys dont mind..Little rusty right now but I got the wd-40 out so hopefully I can get my wheels a turning again.. Dont worry Ill search 1st had a ht account before but couldnt remember password and email was closed lol oh well anyway back to the subject at hand..
Just thought I would share my project with you. I started this back in 05/06 some where in there. Back then goal was to get it as light and fast as possible..So went little crazy..Still my goal light and fast just gonna do it little cleaner this time around..well before I could finish it and track it I went thru a divorce.. Long story short car sat for 4 years at ex's.well in past week the stars lined up just right and I was given the chance to get it back.. Well needless to say I jumped on this chance as I have wanted to finish this project and see what its able to do. So this is how it sits at moment..But there are alot of changes in the works for it..Hope to run it next year..
Motor is a D16z6. Bottom end was sleeved and built by Golden Eagle, Head is completly redone bigger valves springs ported and poloshed with a comp 59300 cam, Neukin exhaust manifold, downpipe, Gt3076r turbo, crane ignition and more have to go thru the receipt book to get all the details been awhile...But will post when I get a chance just wanted to share my excitment with HT guys!!
Old Aug 28, 2010 | 10:18 PM
gutted-dx's Avatar
Default Re: Montana D16z6 build back to life!!!
Glad you got her back! Good Luck with finishing it.
Old Aug 28, 2010 | 11:26 PM
turb0teg's Avatar
I know you got it there, but DAMN that's a good (re)starting point!
Old Aug 29, 2010 | 04:09 AM
blackeg's Avatar
i know!. i started 5 months ago with a bone stock 95 ex. had to gut the car, weld the cage, build the motor etc...
i think one of the things that might have changed the most is engine management. what program did you have the car running on?
Old Aug 29, 2010 | 07:20 AM
dyno76's Avatar
never even got car really running..Had a Hondata for it but never got to put it in..Well needles to say I need a engine managment thinking of S300 but not sure yet..What dopeople suggest?
Old Aug 29, 2010 | 08:30 AM
hyboost's Avatar
I have a d16y8 stock motor with an 58 billet i had crome pro before sucked(made 211@10lbs) driveablity sucked. Went with an s300 made (258@12lbs) ac works drivablity is great 20MPG. boost by gear is great
S300 FTW
Old Aug 29, 2010 | 03:14 PM
Autoworks's Avatar
DSeries and S300 FTW!
Old Aug 29, 2010 | 03:32 PM
myrakle's Avatar
good luck with her, this time around
Old Aug 29, 2010 | 08:23 PM
Mr. Em1's Avatar
s300 is awesome! good luck with it
Old Aug 29, 2010 | 08:27 PM
vectorsolid's Avatar
in for more pics!
Old Aug 29, 2010 | 08:35 PM
dyno76's Avatar
Thanks guys..I will be getting anothe s300 wish I wouldnt of sold the one I had month ago lol thats way life goes though!!! Will post more pics once I start cleaning everything up on it and installing new products..On the hunt as we speak
Old Aug 29, 2010 | 08:40 PM
shietzitzkien's Avatar
gl
Old Aug 30, 2010 | 01:56 AM
1992Si's Avatar
Keep us updated, will be nice to see what she run's.
Old Sep 3, 2010 | 09:06 PM
dyno76's Avatar
Well pulled the head off today to see how the insides look after 4 years.. Small amount of rust on walls so gonna send block to machine shop and rering it or go with different pistons...
Old Sep 14, 2010 | 12:47 PM
dyno76's Avatar
Block is ready to go to machine shop once I decide whether to rering it or go with new pistons
Old Sep 14, 2010 | 01:40 PM
cibao2ner's Avatar
single cams tech has come alongway in 4 years...but how can you have left that car for 4 years parked...if the block is apart get new bearings get a hone looser clearances and go for 6-700hp....speed factory made over 600 on a stock sleeve vitara d16...also look into bisimoto cams...
Old Nov 28, 2010 | 08:00 AM
dyno76's Avatar
Been awhile on updates but I have been going back and forth on whether to do the D2B!! Well purchased B tranny yesterday! So I will update with pictures when I get started on this setup, will also put up some pics of my valve cover and catch can when it gets back from powdercoater!!
Hopefully now this project starts coming together so that it can be done by spring!!
Old Nov 29, 2010 | 01:03 AM
1992Si's Avatar
Great to see your still after it. Keep us updated on the D2B set up.
FWIW, go with hard mounts for the tranny and engine. I had 1/4" steel plate made for the crank pulley end of the block and a L bracket with gusset on the front of the tranny. Both went forward to where the traction bar mounted. IMO you don't want the driveline moving around while trying to shift gears.
Old Nov 29, 2010 | 03:49 AM
sonicivic's Avatar
lookn good man keep it goin!
Old Nov 30, 2010 | 01:36 PM
BLK2DOOR's Avatar
NepTune ftw.
Old Nov 30, 2010 | 04:43 PM
dyno76's Avatar
Definetly going with solid mounts!! Cant wait for Tranny to get here really looking forward to getting started on this!!
Old Dec 1, 2010 | 11:06 AM
Terrible One's Avatar
i love d series builds. subscribed! what are your goals?
Old Dec 1, 2010 | 02:10 PM
dyno76's Avatar
Honestly I would like nothing more than to be somewhere in the 550-640 whp range. Running a low 10 with maybe hitting a very high 9 in the 1320..But wanting and what will happen are of course 2 different things!! But in theory with the changes I am making I should be able to obtain these goals eventually!! Guess I will have to wait and see what happens when I get it all back together and running again..
Old Dec 4, 2010 | 03:36 PM
dyno76's Avatar
Buddy that fabbed my valve cover sent me this pic of it after powder coater got done with it!!! Cant wait for this to be on the motor and in the car!!!
Old Dec 6, 2010 | 11:00 PM
Welcome to the next of level of breaking stuff you didn't think would break.
Valve cover is pimpin.
