bent valves?
Old Aug 28, 2010 | 09:21 PM
andera's Avatar
Default bent valves?
I just turned camshaft sprocket a qtr turn without timing belt installed and the number 1 piston at TDC. any chance i bent valves? i didn't realize what i did until i noticed the 1 piston wasn't at tdc it was a little off, but before turning hte cams it was spot on. just curious if anyone else has done this
Old Aug 28, 2010 | 09:31 PM
hondawhiz's Avatar
Default Re: bent valves?
valves are pretty hard to bend. i doubt you bent them by hand. just put it all together and compression test.
Old Aug 28, 2010 | 09:39 PM
phootbag's Avatar
I've had it happen to me. I've seen it happen to others. I've never seen a valve bend this way. Though, I'm sure it's possible.
Old Aug 29, 2010 | 07:42 PM
F20B_accord's Avatar
well itd be hard to do that but if you real wanna know take off the head
twentyhurtz
Sep 15, 2009 10:38 AM
loc_yaj
Apr 12, 2008 06:40 PM
smokey2.0
Dec 27, 2003 05:18 AM
tha Big EZ
Aug 11, 2003 09:50 AM
LB CRX
Jun 25, 2002 05:17 PM
