Something is leaking..???!!
Hello,
I have a B20 Vtec (b20 block with b16 head) in my 91 crx.. it is also turbocharged.. it is leaking fluid, but I can't tell what it is!!!
It's not coolant.. so it can only be:
-oil
-brake fluid
-transmission fluid
-clutch fluid??
Sorry im a noob!! am i missing any other fluids??? any ideas??
thanks!!!
-oil
-brake fluid
-transmission fluid
-clutch fluid??
thanks!!!
you got the right possibilities. what color is it? where along the engine or trans side is it leaking from? Drain plug??? transmission seal? (Axle seal) , turbo return line or feed?
touch the fluid and rub it between your fingers, if its slippery like oil then u can knock out clutch and brake fluid from ur list. if its kinda sticky then its brake fluid.
No really, DONT
IF you cant identify fluids, you wont be able to identify when the motor is going.
a b20-vtec sonversion is VERY picky about how it is run.
It must be tuned to be used.
How is the car tuned?
If not tuned, the car is a fake, or ready to die
ITs not good to get your hands dirty with a potential suicide motor
its tuned on crome on a P72.. ive been driving it kinda hard lately and i know i got an exhaust leak.. im guessing its from one of the gaskets but cant tell where.. is it possible for oil to leak from a bad gasket or any of the turbo gaskets??
well yea.. you could have a leak from the turbo oil feed line among other things
i can check for fluid levels they seem good.. it was just a few drops so thats why im having a hard time finding the leak.. im def gonna keep checking the levels.. i mean i can do basic stuff like change oil, filter, spark plugs, basic bolt ons, but ive never had a turbo car so im just a bit confused but am hoping to learn how to troubleshoot/fix turbo cars with this one.. its just tricky since its a b20vtec..
so oil can leak from bad turbo gaskets??? (i know sounds like a dumb question but ive never owned a turbo car before..)
The first problem was buying someone elses project.
Where is it leaking from? Where did you notice the leak? This would be helpful to finding you an answer.
Bad_dude
May 27, 2008 11:16 AM
crxforum
Jun 30, 2007 09:58 AM
