r18 procivic turbo kit 06+civic
PRICE REDUCED!!!! MAKE ME AN OFFER !!!
$1500
I just recently installed a procivic tsi turbo kit to my 07 civic 4dr that has the r18motor at profunction.
The turbo kit has less than 1000 miles on it just recently installed about a month ago. I have the reciepts and everything else. The turbo is still on the vehicle but I will have profunction uninstall it for me. Everything included from procivic.com, my kit has the AEM Fuel Management System.
Key Features:
About a 50% gain in horsepower! The new turbo we now include ups the power to about 220 flywheel horsepower (about 200 whp) on your 2006+ Civic DX/LX/EX. See the Dyno Results (keep in mind this Civic does have a larger exhaust than stock).
Completely bolt-on installation.
Will work with stock engine internals (the only exception is that your clutch will need to be replaced sooner than recommended by Honda).
Garrett GT25 turbo w/ internal wastegate set to 6-7 PSI.
Cast manifold that comes preassembled on Garrett turbo. Cast manifold replaces stock catalytic converter for optimal performance.
Features 4 high-performance Honda 410 cc/min fuel injectors w/ clips. These Honda injectors are special in that they are designed for turbo vehicles and have very good fuel atomization properties.
The Hondata FlashPro tuning solution (with base map) also works right out of the box, but will not yet work on automatic transmission Civics. Despite coming with a base map, you may find that some minor tuning adjustments are necessary.
This kit can also be run with other tuning solutions, but no base map will be supplied.
No matter which tuning solution you use, we still do recommend getting your vehicle tuned by a professional. This is the best way to achieve maximum power gains.
Down pipe and gasket.
Polished charge piping.
High-flow intercooler.
Stainless steel braided oil line and fittings.
Stainless steel braided water lines for turbo cooling.
Blow off valve (recirculating).
Now works with your factory heat shield (the heat shield in the picture is no longer included).
High-performance air intake and filter.
Oil return hose and oil pan fitting.
All hardware, pressure lines, hoses, clamps, and couplers.
Installation instructions and wiring diagram (for customer who don't purchase the plug and play harness).
5 year warranty on cast parts, 1 year for accessories, and the full Garrett manufacturer's warranty for the turbo.
Asking price: 1700
get at me on my cell 630-965-8457
$1500
Key Features:
Asking price: 1700
