91 turbo civic clutch question
Old Aug 28, 2010 | 12:44 PM
jester1614's Avatar
Default 91 turbo civic clutch question
I am getting a 91 civic 2 door hatch with a 91 si trans and a 95ish civic sohc d16y7 motor (correct me if i am wrong). it needs a clutch. the motor is stock and runs 14lbs of boost (13b turbo off of a 1g auto eagle talon) through bigger injectors and is tuned and intercooled. the car will be my daily driver (clutch needs moderate street manners) and will see the track occasionally as well. I am guessing the motor makes between 200-225 at the wheels.
what clutch should i buy I am looking to spend about 300-400 bucks excluding flywheel and i dont care if it is puck or stock style disk.
my track car is a 94 ta that should run 11s heads and cam built trans and rear with 4.11s
thanks for the help
gabe.
Old Aug 29, 2010 | 12:00 AM
hatchet_honda's Avatar
Default Re: 91 turbo civic clutch question
exedy or act are good. i have act stage 3. N/A tho..
EFstyle
Oct 28, 2008 08:58 PM
therealzk
Oct 31, 2007 09:37 AM
Dspad_91Civic
Mar 17, 2004 03:43 PM
91civicsizc
Mar 8, 2003 10:15 PM
