Problem with rev limit and VTEC crossover: ECU, tach, or distributor?
Old Aug 28, 2010 | 11:19 AM
michaelsej1's Avatar
Icon2 Problem with rev limit and VTEC crossover: ECU, tach, or distributor?
i have a chipped ecu,vtec crossed at the wrong rpm and hit a limiter at 7200.phearable seems to think its my tach.i have a 95 civic ex with a b16 and a 4.7 type r trans.what car should i get a speed sensor for?
Old Aug 28, 2010 | 11:20 AM
EJeff8's Avatar
Default Re: speedo sensor?
VSS has nothing to do with your tach. Also, you have a B16 with a D series cluster most likely. Your tach doesn't match to the engine.
EDIT: Because the tach isn't original to the engine, I'd assume that it won't run the same as the right tach to the engine.
Old Aug 28, 2010 | 11:53 AM
94EG8's Avatar
Seagull Management
Tach makes no difference. Doesn't matter if its D,B,F,H,K etc.
Old Aug 28, 2010 | 12:25 PM
EJeff8's Avatar
^Well, I meant rev limiter would read different on the physical picture but okay,
Old Aug 28, 2010 | 01:58 PM
well does anyone have any idea why vtec crossover and my limiter would just up and change?i thought the tach ran off the distributor anyways not the speedo sensor?ive never had any trouble with my cluster and to this day seems to be working fine.would it be the chip or ecu?
Old Aug 28, 2010 | 02:02 PM
when rywire tuned it they set the limiter at 7800 and vtec crossover at 5500.vtec crossed two days ago at 4500 and the limiter hit at 7200.ran good up until 6500 then was dead on its ***.i pulled the ecu out then after checking it over re-installed it and it worked just fine.no check engine lights ever,well besides the rev limit still hits at 7200
Old Aug 28, 2010 | 02:05 PM
fyi its a obd1 b16 and my car is obd1 cluster should work just the same
Old Sep 4, 2010 | 12:59 PM
virgineg6's Avatar
sounds like an ecu problem
Old Sep 4, 2010 | 02:01 PM
Former User's Avatar
Default Re: Problem with rev limit and VTEC crossover: ECU, tach, or distributor?
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Old Sep 4, 2010 | 04:18 PM
eg_21's Avatar
they sent you the wrong chip.
Old Sep 24, 2010 | 03:29 PM
its my distributor.i swapped a new one on and its fine.plus i ran the ecu in a friends car,limiter is at 9k.thanks
Old Sep 24, 2010 | 04:16 PM
EJeff8's Avatar
^ I like how you used your friend's car to test limiter
Old Sep 27, 2010 | 06:18 PM
haha thanks
TcUiRvBiOc
Sep 10, 2009 02:59 PM
G2integra217
Jun 12, 2005 11:13 AM
WhiteGSR95
Mar 29, 2005 08:11 AM
integra-modder
Oct 27, 2002 01:44 AM
