burning lots of oil...wuts my problem
after 2500miles of normal driving (ie vtec several times a week), my car runs outta engine oil...my bumper is filled with black dots...i use mobil 1 5w-30 motor oil
a friend has told me my problem is the piston rings (fried) and i believe him, but i'm hoping the problem isn't a big
could someone share their thoughts?
Your friend is probably right.
Do you warm up and cool down your car at all? Or just drive it *****-out as soon as the starter does its job?
I use mobil 10w-30 and it just about always breaks down. I just took it as the oil itself breaking down. EDIT: i'm a little over 3K miles and i've already added 2.5 quarts.
[Modified by RacerXI, 9:57 PM 9/17/2002]
does that account for my piston rings or is that the reason i burn lots of oil? thx
problem is probably ring related. not much you can do except tear it apart and put new rings in, but that $$$ unless you can do it yourself. dont know what to tell you.
Here is what I just went through.
OIL spots on bumper.. burn 1 Quart in 20 min on track
~3 quarts in 3000 miles of normal driving.
Compression great 245-233 across (Stock motor)... leakdown less than 5%
My oil rings were bad.. not compression rings. Spark plugs looked decent, because the oil was blowing by at such high RPM.
Pennzoil.....5w30 is your friend.
Andy: Who doesn't burn any oil and has had no problems! If they use it on the Space Aircrafts, its good for the R and Hatchcrap.
Mobil 1 is great.....but $ and burning makes me
personally, I'm partial to Castrol 5w30 synthetic...little to no burning (and I'm in vtec for atleast ~30mins per day or ~50 times daily)
but I'll be switching to RedLine soon.
-Marc ---> who just found his old "NOS" shirt during the move to the new house and will wear it at the next meet
Most of the drivers that I have met in the past who RACE their Type R report oil burning issues. Stock motors, modified motors - doesn't matter. Just make sure you CHECK THE OIL RELIGIOUSLY and don't let it get below 1/2.
The other thing you might check - that might help is the PCV valve. This is a cheap item to replace.
Besides - oil is a consumable. Only do the rings if you absolutely have to.
I only burn about a guart every 3,000 miles then i just get it changed. I'm thinking about switching from mobile 1 to something different.
U have to figure with those kind of RPM's your bound to burn more oil when your picking so much up all the time in Vtec! NO............
Andy: Who likes AssPenny's idea.......I need NOS
I will be putting it in tonight!
-Dave, who burns 0.0000000 quarts with two full tanks of gas in a day at a hin HPDS.
Drinker
