z6 into ek
Old Aug 27, 2010 | 09:46 PM
PardonmyEK9's Avatar
Default z6 into ek
if i have a obd2 to obd1 jumper harness do i need to change everything else to obd1?
Old Aug 27, 2010 | 09:52 PM
hondawhiz's Avatar
Default Re: z6 into ek
no. the crank angle sensor just wont plug in. everything is plug and play. if u have the upright throttle body manifold on the ek. keep if for the z6.
Old Aug 28, 2010 | 03:40 AM
94EG8's Avatar
Seagull Management
Most of that isn't true. CKF sensor wont plug is because the Z6 ECU doesn't have on, you're running an OBD1 ECU so it doesn't matter anyway. You can't use the Y7 intake manifold because of the 3 wire IACV (besides that they don't flow well anyway) The swap is not entirely plug and play, you'll want to reuse the OBD2 alternator and get a set of Y8 or OBD2 B-series injectors. You will either have to build a custom distributor using the Z6 housing and OBD2 CKP/CYL/TDC sensors, or use an adapter harness or cut and splice distributor plugs.
Old Aug 28, 2010 | 04:13 AM
machine4321's Avatar
I cut off the obd2 plug and soldered on the z6 dizzy plug. there is some wire extending you have to do for the sensors on the intake manifold.( i just cut off all the tape and wire loom and rerouted most of the sensors and that was enough) the IAT needs to be extended (dotn mix it up with the purge sol.)
Old Aug 28, 2010 | 04:14 AM
HondaPartsHero's Avatar
Technical Hero
You'll also need to swap the Y7's IAT plug (square) over to the Z6 style (round) or put the Y7 IAT into your intake arm.
Austin_22
Mar 24, 2014 08:06 PM
Frost7177
Jun 27, 2007 06:26 PM
Aquafina
Jun 8, 2007 02:18 PM
Ron Burgandy
Apr 13, 2007 07:42 PM
