keeping the single cam but need some help
Old Aug 27, 2010 | 06:20 PM
AccordCoupe716's Avatar
Default keeping the single cam but need some help
i was looking at the parts i want an the body work that needs to be done and im not gonna have enough for a h22 swap and putting the motor in so what are some things to make the single cam a lil faster i have a lx non vtec motor so i kno theres not much! im gonna replace my intake,headers and exhaust is there anything else? i got high miles so im not trying to boost yet but its there any pistons or cams and stuff like that i could use?
Old Aug 27, 2010 | 08:06 PM
tamadrummer1120's Avatar
Default Re: keeping the single cam but need some help
well there is the g22 swap. which is the h22 head on the f22 bottom end. would be good because it is DOHC and has vtec, so it would really give you a nice power pick up. could also use some nice aftermarket intake manifolds at that point, or the euro-r intake.
also could just do the f22b1 head swap so you have vtec. do intake/exhaust/headers. maybe a small cam.
Old Aug 27, 2010 | 09:07 PM
Thanks alot I was thinking about doing that thanks for the reply
Old Aug 27, 2010 | 09:44 PM
92civlude's Avatar
A lightened flywheel perhaps?
Old Aug 27, 2010 | 10:29 PM
chikin pickle's Avatar
It depends on how much you are willing to tear down the motor. There is the usual I/H/E. You can also do a camshaft, flywheel possibly, and a good tune. Anything more than that and you have to disassemble things.
If you have a CB7 with an F22a you can swap in an a6 or H23 intake manifold with dual runners.
Old Aug 28, 2010 | 07:16 AM
im looking at buting a h22 motor and using my f22 tranny for now
Old Aug 28, 2010 | 07:37 AM
92civlude's Avatar
Your not going to like the looong gear ratios of the F22 trans.
Old Aug 28, 2010 | 07:59 AM
GhostAccord's Avatar
I replied to your post on gencrapalive.com
Cam
head work
intake manifold
internals (pistons + machine shop work)
and a tune
or boost and a tune
A complete H swap would be ideal but you said that was out of your budget. So if the H swap is out of your budget your probably looking at NO2 being your best bang for your buck.
What is your budget? That might give people the ability to actually give you a list of affordable options for you. Because even just buying and installing new pistons can get expensive.
Pistons - $300-$500 (+ hone or bore)
Cam - $300-$400 (+ valve train components for anything more than level/stage 1. that's another $400+)
Tuning - $300-$500
Old Aug 28, 2010 | 09:08 AM
Not sure what my budget is yet I'm getting body work done first
turbo90accord
Jan 16, 2010 09:27 PM
rico892002
Aug 19, 2009 08:38 PM
Bright13
Jul 23, 2009 01:36 PM
lrayford
Oct 24, 2008 06:34 PM
bluedlude
Dec 13, 2006 05:28 PM
