Crank Pulley Worry.
Old Aug 27, 2010 | 03:28 PM
SIRIUS VTEC's Avatar
Default Crank Pulley Worry.
So i spent a day getting the d16t8 to TDC both the crank and the Cam gear and i finally got it where i wanted it. I noticed the tensioner was too tight so i loosened up the lil tensioner bolt through the plastic cover and i got the belt onto the cam gear and i turned it a few times as recommended. I Noticed every time i turned a full turn it would make a click sound as if something was hitting the plower timing belt cover as it turned. Anyways i put the motor in the car and today im goingg to torque the crank. Im nervous about starting the car now. IDK if it'll keep making that clicking sound during the timing belt rotation..has anyone had this problem i really dont wanna have to take this cover off again..its a pain in the ***.
Does anyone's motor make a big click sound on a full turn of the crankk?
Old Aug 27, 2010 | 04:26 PM
Default Re: Crank Pulley Worry.
what do u guys think
Old Aug 27, 2010 | 04:41 PM
stickboks's Avatar
my d16z6 sounds smooth, just the sounds of the valves. if its making a clicking noise, id pull off the cover just rotate it again and again like your doing and look for contact or where that sound is coming from. no belt can really "hit" a cover, it can rub up against it (unless a part is "out of round" then intermittent cantact can occur). but a click could be a tentioner that got some moisture inside and some calcium/rust built up. maybe you over torqued the tentioner? your motor is #1 tdc on the intake stroke yeah? did you ever do a valve lash? if so receck torque on the nuts. even little clicks can cause big problems down the road so your smart for being cautions.
Old Aug 28, 2010 | 06:36 AM
Thanks for the help stickboks
Here's the thing i notices about it this morning, when i turn the crank pulley myself it makes one Big CLICK sound whenever im BDC not TDC. So i rotate it and when it hit BDC i here a loud CLICK or a pop. Im gonna try and get some video footage of it but im a lil cautious about this. I dont feel like removing the crank pulley again after i just had someone torque it to spec for me.
Old Aug 28, 2010 | 06:49 AM
I'm turning it clockwise i just realized the timing belt turned counter clockwise..could this be the reason for the click at BDC?
Old Aug 28, 2010 | 07:30 AM
I went out and did it counter clockwise and its the sae sound im uploading a video now
Old Aug 28, 2010 | 07:38 AM
lunareg's Avatar
oh geez man, this sounds like a real pain in the *** >.< waiting on the video for a better idea.
Old Aug 28, 2010 | 07:58 AM
That's the video there. @ :33 and again at 1:24
Any idea what this sound is?
Old Aug 28, 2010 | 07:59 AM
If it helps, i dont have any oil or fluid in the car yet it's still dry. a/c p/s alternator...all that's hooked up.
Old Aug 28, 2010 | 08:06 AM
doop doop
Old Aug 28, 2010 | 08:07 AM
RACEPAK's Avatar
bmp4u
Old Aug 28, 2010 | 08:12 AM
do the hustle, not the hassle.
Old Aug 28, 2010 | 08:21 AM
lunareg's Avatar
****, thats strange. I cant say for sure, but i'd want to make sure it was no big deal before I called everything a day and took off driving.
Old Aug 28, 2010 | 08:29 AM
I agree with you on that illa-noise. Im thinking about putting the wheels on the car and pushing it to a shop.
Old Aug 28, 2010 | 08:39 AM
94civiccupew/b7's Avatar
yeah that doesn't sound right. i would pull it apart and check out the tensioner. does the belt get loose after the click? i wouldn't chance leaving it that way
Old Aug 28, 2010 | 09:28 AM
Yeah unfortunately that's what i'm afraid of I don't wanna drop the motor again and have to do this all over school starts Monday and i need the car by then.
ANYONE else had this problem?
Old Aug 28, 2010 | 10:38 AM
even worse than i thought, it's a bent valve.
Old Aug 28, 2010 | 10:47 AM
lunareg's Avatar
oh wow thats shitty :/ but at least you dont need to take the bottom end apart, you can pull the head and fix it pretty easy.
Old Aug 28, 2010 | 10:58 AM
Yeah, thank God for that. Im just worried that maybe whatever caused this bent valve also ****ed up the pistons maybe..like maybe it's a root to other problems once i take the head off. If it's nothing else wrong with it then i'll just use the valve from my old motor. Onle other issue is im not 100% on valve adjusting but im sure i can find resources.
Old Aug 28, 2010 | 11:19 AM
lunareg's Avatar
yeah im not a big fan of headwork, its kinda a pain in the nuts. def do some research
Old Aug 28, 2010 | 11:31 AM
EJeff8's Avatar
^Ha. Headwork, nuts. Kudos.
Old Aug 28, 2010 | 12:12 PM
lunareg's Avatar
c what i did ther lol
Old Aug 28, 2010 | 01:59 PM
lol u dudes are funny as hell. lol. Toast to a headjob..i mean headwork. I needa find out how to clean a valve.
Old Aug 28, 2010 | 03:49 PM
EJeff8's Avatar
If your gf shines a head pretty well, I'd ask here.
Old Aug 28, 2010 | 04:01 PM
hahahaha thats a low blow...no pun intended.
