Transmission Issue
Old Aug 27, 2010 | 01:00 PM
shaylude's Avatar
Default Transmission Issue
I've searched for two days now and i'm really just lost.
Recently installed a new transmission, competition flywheel, and competition clutch...
The transmission shifts into all gears perfect when not running.
When running the car does not move forward so I don't think it is disengagement problem.
But when the car is running it is almost completely impossible to shift into any gear unless you really force it.
Cables look good.
Oil level is spot on.
S/C fluid level good..
The only real adjustments I can find is just adjusting the clutch pedal and i'm pretty sure that I don't need that.
Maybe re-bleed the clutch?
Any ideas?.. if I haven't confused you.
Old Aug 27, 2010 | 02:38 PM
Enzo15's Avatar
Default Re: Transmission Issue
Try rebleeding, but Im gonna go with the competition clutch. They really are not that good.
http://www.scionlife.com/forums/show...etition+clutch
Old Aug 30, 2010 | 12:13 AM
this_guy's Avatar
It's your clutch. A spring has popped out, because this JUST happened to me last week, and your symptoms were exactly the same as mine. Car off, I could shift into gears; car on, I could not.
Old Aug 30, 2010 | 11:10 AM
1GPlusSH's Avatar
just shift without clutching...it's a waste of time
good luck with whatever new clutch you go with
Old Aug 30, 2010 | 01:03 PM
pintobean's Avatar
I believe it's the clutch. It may not have been aligned or popped out of alignment. Did you use the alignment pin?
Old Sep 1, 2010 | 05:13 AM
mrbleegs's Avatar
Probably the clutch spring like this_guy said. It happened to me too. You'll need to drop the trans.
Old Sep 1, 2010 | 08:58 AM
Apex1972's Avatar
competition clutch has pretty good customer service,they replaced my stage 2 unit even though it was just out of warranty when the spring popped out. I sold the new one though. factory Honda clutch is working so much better.
d_fuentes
Transmission & Drivetrain
Dec 17, 2016 10:15 PM
RG400SmartTowel
Jul 28, 2009 06:07 AM
bob_long737
Aug 19, 2008 07:41 PM
bow tie
16
Apr 3, 2007 03:49 PM
PAID-$$$
Jun 11, 2004 12:50 PM
